#1 |
I just pulled the front wheels off my '30 coupe today for the first time and was surprised to see there were no grease caps.
After reading, I see they were not originally equipped with them. There are add on caps available from the suppliers though. My question is, do you guys use them? Worthwhile? I am trying to keep the car as original as possible but it is a driver. Thanks
1930 Standard Coupe |
#2 |
I bet the factory thought the hub caps were enough.
#3 |
I use them I think they help keep dirt out, you cant see them anyway with the wheels on.
#4 |
I have never used them. I once did buy a set many, many, years ago. They did not fit properly. So I never put on car.
Enjoy. |
#5 |
The biggest problem with fitting the caps is that the original washer under the nut is too large to let the cap fit down properly. Either get a smaller diameter washer or file/grind down the original and they will fit.
#6 |
John in same place but worse weather . |
#7 | ||
![]() Quote:
Is this the drum you are taking about? ![]() Sent from my iPhone using Tapatalk |
#8 |
The center section of the wheel seals up tight against the brake drum, and the hubcap covers the exposed area of the outer bearing. It's not a perfect seal, but hey, nothing on the Model A is a perfect seal!
#9 |
Ya think you got that picture BIG enough?
Ruth "Sometimes you really DO need to read the whole thread" |
#10 |
#11 |
Yes that is the one as long as it is 11" dia. Some have the part number on the back spokes .
John in Suffolk County England . |
#12 | |
![]() Quote:
They were on my car when I purchased it. A senior club member was surprised to see them and remarked that he had never seen a set. Are these supposed to be better than the original design? Sent from my iPhone using Tapatalk |
#13 | |
![]() Quote:
YEP What Carl said! My car actually has a cap on the drivers side and no cap on the passenger side. SO got a set of replacement caps and the passenger side cap will not fit over the keyed washer therefore my car continues to had a drivers side cap and no passenger side cap ![]() |
#14 |
I reduced the size of your picture and here it is.
I have a couple of these wheels but they are in storage and I haven't seen them in years. Yours looks a little different than what I remember, but if I get to the warehouse today I"ll take pictures and post one for us to compare. Ray |
#15 |
Maybe the large washer was an attempt to keep large dirt out of the bearing.
#16 |
I bought a pair years ago. They did not fit as the inserted part was over size. I carefully ground down the inserted part until it was a snug fit. The have been on ever since modified.
#17 |
I saw on some forum, thought it was this one, that Ford passenger car bearing caps from the early 50's would fit the hubs. I trotted right out in the woods and removed a pair from a junker 52 Customline. As CarlG said, the washer was too large, but not by much. A few seconds at the bench grinder made them small enough to let the cap into the hub without interference.
I rummaged through my inventory of good goods and found a small ball to clamp in my vice and knocked out most of the dents. I guess I neglected to take a picture of them installed, but they fit just fine.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer. |
