Old 01-28-2021, 03:03 PM   #1
RocketsGarage
RocketsGarage's Avatar
Default 1934 Ford pickup project
City: Sunnyside
State: WA
Price: $13,000
‘34 pickup project. I’ve been collecting stuff for this for awhile but to many irons in the fire. The chassis is bare rails that are pretty decent with a little damage on the driver frame horn, doesn't have an X-member. Very nice front and rear crossmembers. Front has an old dropped axle, split bones, posies spring, old modified ’40 spindles & brakes (no guts). Rear has a ‘40 banjo & brakes (no guts, think one drum in bad) with notched spring to fit the ‘34 crossmember, drop shackles, shortened torque tube & ‘46 radius rods. Steering box is stock ‘34 w/ truck column & '34 drop. Cab is really decent, running boards are so-so, front fenders are pretty rough. Bed is a fair original with a little rust in the bulk head. Was disassembled & dipped. It’s just bolted together & comes with new front steak pockets & other parts. Just had parts of the original sub-rails. Tail gate is ‘35. Back fenders are new steel UPI. Grill has rust at bottom & was dipped with the baffle removed. All the little parts are there, latches, window regulators, molding etc. Comes with ‘40 flathead that was rebuilt but sat & got water in one cylinder & side shift trans (not installed). This thing is just all mocked up to look like something & is a project but has allot of potential. Wheels, tires & caps aren’t included but will come with rollers depending on what you want. Other parts available. Washington tile in my name. Message for more info/pictures $13k obo.
Big price drop to $10K
www.RocketsGarage.com
RocketsGarage is offline   Reply With Quote
Old 02-05-2021, 11:14 AM   #2
RocketsGarage
Default Re: 1934 Ford pickup project
Forgot to include that it comes with a better cab top. The one on the pickup cab pictured is a little rough & is the worst part of the cab. There's also another cab with no doors dash etc. that could be included. The cowl is really the only okay part about it but there could be some stuff to use.
Old 02-23-2021, 01:36 PM   #3
RocketsGarage
Possible deliveries
Old 03-22-2021, 12:21 PM   #4
RocketsGarage
Big Price drop to $10K. Truck is currently rolling on a set of 16" '35 Wires.
Old 04-06-2021, 10:39 AM   #5
RocketsGarage
Still have it
Old 04-14-2021, 05:33 PM   #6
RocketsGarage
Someone needs a project
Old 04-20-2021, 12:45 PM   #7
RocketsGarage
Weekday Bump
Old 08-10-2021, 12:56 PM   #8
RocketsGarage
Down to $9000
