#1 |
Oil gauge question below leads me to confirm my ideas on testing a temp gauge.
My plan is to remove it, make certain the capilary tube is not kinked, put the bulb in boiling water and see if it will move off the 160 degrees it is stuck on. Gauge is about 10 years old or so. Want to make certain it's dead before replacing. Anyone have a good source for a Stewart-Warner gauge with a 230 degree max display and a reasonable length cap tube? ![]()
our next Model A has arrived.... ![]() |
#2 |
Why would you want a 230 degree gauge ?
#3 |
The last few 230 deg SW gauges I have used I found the gauge itself either on EBay or at a swap meet and then had to have new tubes fitted to them. I have 230 deg gauges in all my Model A's and feel it is worth the trouble to have them. One thing about having new tubes installed is that you can have them made to the length you want.
Chris W. |
#4 | |
![]() Quote:
I didn’t know the tubes were replaceable. Who does that kind of work? Sent from my iPhone using Tapatalk |
#5 |
There are many companies around that will repair these gauges. Do an online search of "Temperature Gauge capillary tube repair" and see what comes up. I use Abbott Instrument Restoration in Portland Oregon. They have done a lot of work for me thru the years.
Chris W. |
#6 |
Cost me 35 bucks. My 29 runs at 140 on a 65-80 degree day, no thermostat.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer. Last edited by Ak Sourdough; 01-21-2021 at 12:21 AM. |
#7 |
looking for a 230 degree gauge as opposed to a 265.
those seem to be the only 2 options in the SW catalog. many of the gauges listed on line have excessively long capilary tubes, so hope to find the shortest. might just get another Rex-a-co from Brattons- if it lasts 10 more years that will be acceptable. suspect having it repaired or a new tube installed will cost more than a new gauge, especially if there's round trip cross-country shipping included.
