#1 |
Does anyone remember the sheetmetal bead roller that was hand held and operated with a 3/8" ratchet?
Before the web, eastwood had small catalogs that were the size of the early rod and custom magazine. I remember seeing this tool and im pretty sure it was Eastwood but it doesnt look like its made anymore. Closest thing i can find online is a seam closer for standing seam roofing. Maybe im searching with the wrong search names? |
#2 |
Have you tried contacting Eastwood?.....Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
#3 |
Could always make your own similar to this homebrew tipping tool.
#4 |
#5 |
#6 |
#7 |
There may be a reason why Eastwood no longer has this particular item.
![]() Just sayin'. |
#8 |
#9 |
Pure speculation. Most companies do not discontinue successful products for no reason.
In any event, I'd think a 1/2" ratchet would be a better choice, given what it takes to form sheet metal. |
#10 |
What i have to do is close up a hemmed edge on a 8 ft long edge of 24 gauge so 2 rollers 1" wide will work even if i have to go over it a couple times. A hand held tool is easier then handling the sheet by myself and try and run it through a bench mounted bead roller. Using a air ratchet is my plan. I just remembered seeing the ratchet powered one years ago.
#11 |
I think you have a good idea with the air ratchet..... I have an old one that turns slow..... which is good because I don’t move very fast anymore either!....... Mark
#12 |
![]() That is one very interesting original one-off tool? |
#13 |
Back in the 90's, there use to be hand held tool that greatly sped up putting a new door skin on car's door frame. It was called Skin Ease or Ez or something like that. I tried googling it, but nothing came up with those search words.
If it existed then, I'm sure someone improved upon it by now. 24 gauge is lighter than most 18-20 gauge panels, so it should work. |
#14 | |
![]() Quote:
Wivco door "skinner" https://www.autobodytoolmart.com/pro...oor-lock-tools |
#15 |
How would this work
