Old 01-16-2021, 02:15 AM   #1
Lawrie
Lawrie's Avatar
Default transmission case lube
Any one notice the subtle changes to the rear of the trans case to add more lube to the rear bearing.
I had a 35 case and a later one(pictured) on my bench together and the later one has a scollop out between the two top rear engine mount (7085) plate bolts ,this expose the rear mainsheet bearing and slinger so oil will run down into it, the early case does not have this, well my one now has.
Lawrie
File Type: jpg 9FBCC262-46C7-4D66-AB05-43A0532C9B3D.jpg (79.9 KB, 275 views)
File Type: jpg 48D8B577-27EF-4FAE-B81E-89E7C1ED1969.jpg (53.7 KB, 137 views)
Lawrie is offline   Reply With Quote
