Old 01-07-2021, 05:29 PM   #1
Merc Cruzer
Merc Cruzer's Avatar
Default How to make new belt line molding for my 53' Merc convertible
Back on 11/29/20, I placed an add for belt molding with snaps for my 53' Mercury convertible, since mine has been sanded and polished so many times, they had pin holes in them. Not to my surprise, I didn't receive any offers.
I tried e-bay and found a set for $300 that were, in my opinion, beyond salvaging.
I had a theory that a set from a 53' Ford Crestline 2 door (no post), would work. I did find a set on e-bay (for $83.73 including shipping) and inquired as to the length and width. They were the same, except the ends on the Ford pieces were cut at an angle. Not an issue since the ends went under the side molding anyway. Due to their location on a coupe, they were totally undamaged. I have found Ford trim to be less expensive than Mercury trim.
I found snaps, that were mounted with pop rivets ($20, free shipping).
I ordered the belt line and snaps. After they arrived, I polished the belt line pieces. I took measurements from the original pieces, only to find the snaps were not mounted symmetrically from the center. I checked with a few people and they confirmed the original installation of the snaps varied considerably.
To find the center, I measured the opening of the rear window, and halved it, for the center location of the overlapping piece. I used the measurements from the drivers side and duplicated them on the passenger side. When I installed the pop rivets I put washers under the bottom for additional strength.
The pictures below include, my original set on the car, the set I found on e-bay, installation of the snaps, the passenger side before it was polished, taped to the car for mock up and establishing location, and the final product.
Total cost $103.73.
Merc Cruzer is offline   Reply With Quote
Old 01-07-2021, 07:19 PM   #2
Zeke3
Zeke3's Avatar
Default Re: How to make new belt line molding for my 53' Merc convertible
Great solution for replacing the molding. Also, I really like your car, it is a great example of an early fifties convertible, especially the color.
Zeke3 is offline   Reply With Quote
Old 01-07-2021, 07:23 PM   #3
tubman
tubman's Avatar
Excellent Job! Looks factory to me.
Old 01-08-2021, 08:13 AM   #4
corvette8n
corvette8n's Avatar
Great job.
Old 01-08-2021, 03:29 PM   #5
mercman from oz
mercman from oz's Avatar
Lovely car in a vert scenic location. Glad that you were able to replace that damaged belt molding with ingenuity. Good work.
Old 01-08-2021, 08:51 PM   #6
53MERC
53MERC's Avatar
Roy,
You Sir always find a solution. Great job.
I remember you and Brenda telling me that if they don't make the part you have to improvise.
You have been a great help to me and my Merc.
I hope the three of you are doing great.
53MERC is offline   Reply With Quote
Old 01-09-2021, 11:40 AM   #7
Merc Cruzer
Thank you all for the feedback. For many of us, the hobby has become very expensive, and many times prohibitive. The goal was to hopefully help someone, be able to use the information, to save a few dollars, and provide an alternative, with today's searches, for what has become, overpriced and impossible to get, parts.
Old 01-09-2021, 12:59 PM   #8
Robz51
Robz51's Avatar
Always enjoy seeing pictures of your car Roy.
Rob
Sent from my SM-G955U1 using Tapatalk
Robz51 is offline   Reply With Quote
Old 01-09-2021, 01:38 PM   #9
Merc Cruzer
Rob
Thanks, it was taken in front of the house, across the street, last fall. Just lucky to live in Colorado I guess.
For many of us, the hobby has become very expensive, and at times prohibitive. The goal was to hopefully help someone, be able to use this information, to save a few dollars, and provide an alternative, while searching for what has become too often, overpriced and impossible to get, parts.
