Old 01-04-2021, 09:11 PM   #1
phil pavicich
Default 40 ford rear hub sleeves
I Have just pulled down some old stock 40 rear hubs and the outer dia of the hub has lots of pitting ,(water /rust damage from sitting a long time ) is this a sleeve inside there or is it original machined hub surface , Is there a sleeve available to press in and fit smaller od bearings ? or am i up for new hubs
Thanks In advance Phil
phil pavicich is offline   Reply With Quote
