Old 12-24-2020, 10:40 AM   #1
V8 Bob
V8 Bob's Avatar
Default '40 Garnish screws
I need a few #8 slotted oval head screws that are close to 1 1/4" long for the windshield garnish in my '40. The 1" screws I purchased from Roy Nacewicz years ago are marginal in a few locations. I found some 1 1/4" stainless oval heads from the hardware store that work fine, but the phillips heads are out of place. I sent an Email to Third Gen but so far no reply. No luck with McMaster-Carr. Would appreciate any leads. Thanks.
Merry Christmas.
V8 Bob is offline   Reply With Quote
Old 12-24-2020, 10:51 AM   #2
rich b
rich b's Avatar
Default Re: '40 Garnish screws
https://www.ebay.com/itm/8-Sheet-Met...EAAOSw6QpbTjNJ
This is what I used for garnish; ordered some 1", 1-1/4". along with some 1-1/2" for good measure. They polish up well.
rich b is offline   Reply With Quote
Old 12-24-2020, 12:28 PM   #3
V8 Bob
V8 Bob's Avatar
rich b,
Never thought to check with Ebay, or the internet! Figured these were specialized vintage automotive hardware. Thanks for the reply, and Merry Christmas!
Old 12-24-2020, 12:37 PM   #4
deuce_roadster
deuce_roadster's Avatar
Restoration Specialties has oval head slotted stainless screws you can polish.
Great people, I got all the slotted screws for my 40 wagon from them. They are in PA. Give them a call or look on line. Their catalog lists more then their online version so if you don't see what you want just ask.
http://www.restorationspecialties.com/
Old 12-24-2020, 12:40 PM   #5
51woodie
51woodie's Avatar
Try the specialty bolts/screws trays at Home Depot or Lowes They both have quite a selection of all kinds of screws, bolts, nuts, clips, bushings, shims, rubber grommets etc.
51woodie is offline   Reply With Quote
Old 12-24-2020, 12:46 PM   #6
woodiewagon46
McMaster-Carr has any type and size oval head screw you could want.
woodiewagon46 is offline   Reply With Quote
Old 12-24-2020, 01:14 PM   #7
V8 Bob
V8 Bob's Avatar
Thank you deuce and 51.
Woodiewagon46, McMaster-Carr is my normal go-to hardware store, but I could not find any slotted oval head sheet metal screws on-line. If you have, could you show me the info?
Old 12-24-2020, 01:20 PM   #8
Clem Clement
Clem Clement's Avatar
When did Henry start with Philips screws? The were invented in1933. Caddy/LaSalle started using them in 1936 or so.
Clem Clement is offline   Reply With Quote
Old 12-24-2020, 02:15 PM   #9
hotrodart
hotrodart's Avatar
For $6.78 I hope you got at least 10 in the package, not just one!! Ouch!!
hotrodart is offline   Reply With Quote
Old 12-24-2020, 02:26 PM   #10
rockfla
rockfla's Avatar
I can sell you any size SS oval slot TypA tapping screws you want!! Email what you need and how many and I can fix you up!!! [email protected]. I will back in the office Monday.
Old 12-24-2020, 03:29 PM   #11
V8 Bob
V8 Bob's Avatar
Thanks rockfla,
I'm not familiar with the description "type A tapping screw" so is that just a regular pointed sheet metal screw? I don't want to damage or enlarge the holes already in the body.
Old 12-24-2020, 04:16 PM   #12
F1 MIKE
F1 MIKE's Avatar
BOB when we did are 40 i went to the BOLT DEPOT .COM Slotted ovel tapping SS call to order.
F1 MIKE is offline   Reply With Quote
Old 12-24-2020, 06:41 PM   #13
rockfla
rockfla's Avatar
Originally Posted by V8 Bob View Post
Thanks rockfla,
Yes, the “Typ A” is the “technical” term for the standard sheet metal screw!! They sizes are standard #6, 8 10 so you shouldnÂ’t have any issue with existing hole enlargement
Old 12-25-2020, 12:05 AM   #14
rich b
rich b's Avatar
That's 50 screws for the money.
Old 12-25-2020, 06:24 AM   #15
flatmotor40
flatmotor40's Avatar
I buy most all my screws and bolts for Bolt Depot.
flatmotor40 is offline   Reply With Quote
Old 12-25-2020, 09:43 AM   #16
35fordtn
35fordtn's Avatar
Bob, I received your email and responded the next day. Since it was a Roy item I’d gladly send you some 1-1/8 and 1-1/4 long as many as you need free of charge, however we are closed until January 4th so it’ll be till then before I could ship them
35fordtn is offline   Reply With Quote
Old 12-25-2020, 10:55 AM   #17
V8 Bob
V8 Bob's Avatar
Michael, I found your Email and sent you and answer. I had mistakenly trashed it because I didn't recognize it. My Bad!
To everybody else, thank you for your input. Merry Christmas and much Happier New Year!
Old 12-25-2020, 01:14 PM   #18
19Fordy
19Fordy's Avatar
I recall Ace Hardware used to carry slotted sheet metal screws.
Old 12-25-2020, 01:22 PM   #19
Jacques1960
Jacques1960's Avatar
Hamilton Marine offers extremely high quality fasteners in all shapes / sizes.
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 12-25-2020, 02:20 PM   #20
V8 Bob
V8 Bob's Avatar
The slotted sheet metal screws in our local Ace are either flat or aluminum oval headed.
