#1 |
I'm beginning to notice excessive rattling with the windshield in my '28 Tudor. It's definitely occurring between the glass and the windshield frame. Does anyone have any quick fixes? If not, references for working in this area that includes removing the frame from the hinge, glass from the frame, and then re-installing glass with glass setting tape and gasket. Warning - I'm a rookie in this area.
#2 |
I'd love to know as well for I'll be setting the glass in my roadster soon.
#3 |
I've just sorted a rattle in the windscreen of my '28 Tudor too. It was the screw at the front end of the arm that holds the window open. Once tightened, no rattle.
If your problem is indeed the glass loose in the frame, try a little black silicone around the edges I'd apply it so that some goes in between the glass and the frame, then clean it up Silicone can be removed with Mineral Turpentine easily before it cures.
#4 |
I had an annoying rattle thought it was coming from the top, tightened the 2 screw that hold the frame to body and now nothing.
#5 |
A word of caution:
I would not drive this car until this is fixed. My coupe in the 60's had a windshield where the glass rattled in the frame from the time that we bought it. I drove it for 15,000 miles or so then in 1966 I had an accident where I hit the rear of a 56 Plymouth at 45 MPH that was stopped in front of me. Minimal damage and the seat belt kept me from hitting the windshield and kept my chest from hitting the steering wheel any harder than it did. Arms and muscles were sore afterwards from hanging onto the steering wheel. The Highway Patrol said I was really lucky that I wearing the seat belt. I had no idea how lucky I really was! I drove the car another 20,000 miles until the rattling glass got worse. When I removed the windshield to replace the glass that is when I found that someone years before had put regular old cheap window glass in the frame. Window plate glass breaks into large chunks in an accident and injuries are usually very bad. The glass store explained that window glass is thinner than safety glass so it did not fit tightly in the frame which is made for the thicker safety glass. All Model As had safety glass in windshield from the factory BUT side and rear windows were plate glass. My windows were ALL replaced with laminated safety glass. Last edited by Benson; 12-22-2020 at 07:57 AM. |
#6 |
There are several parts/youtubes in this series, watch them all. https://m.youtube.com/channel/UCf8qU...Y3a5HdQ/videos Bob La Follette |
#7 |
X2 what that lucky so and so Benson said. Boy, that could have been much worse.
#8 | |
![]() Quote:
#9 |
Open car windshield was not covered, not sure how much will be applicable.
#10 | |
![]() Quote:
https://www.maxwarehouse.com/product...t=Low%20Margin |
#11 |
One of the 4 windshields I reworked was plate glass, another was delaminated.
Safety glass, 1/4 inch thick was what I used, not tempered glass. |
#12 |
Saxman,
I had similar problem with my 28 phaeton, glass was loose in the windshield frame. Wanting to drive the car and not go down the potential work of chasing rust and repairing the frame if I removed the glass from the frame, I ran a tidy bead of neutral cure silicone around the perimeter where the glass meets the windshield frame. Make sure all is clean and dry before caulking and clean up glass as desired with brand new razor blades and solvent as desired. This has worked well for the past 8 years and 40K+ miles. If your existing windshield is not laminated glass, please skip the above and install laminated glass. Peace, Phred Elgin IL |
#13 |
Went with metric Auto glass and a solex tint, very light green, like a coke bottle, Bedded the glass in modern urethane sealant. Thicker glass means more stability, urethane means a tight seal with some flexibility.
#14 |
Saxman - I've had the same problem in my 30 pickup and in cars in the past. This is not a terribly difficult job, kind of tedious, but plenty of opportunity to stop and regroup if things don't go smoothly.
If you have any doubt, confirm that the rattle is indeed coming from the windshield in the frame. A business card or two (does anyone still have business cards?) inserted between the glass and the rubber will confirm. I removed the windshield frame from the car, removed the top frame (screws on each side at the top, then "persuaded" with some light wooden mallet action) and then teased the windshield out of the frame. You can use a thin putty knife or a single edge razor blade to drive between glass and the rubber to free up the glass. Clean the glass and the channel thoroughly then begin to insert the new rubber into the channel. Couple of hints:
Good luck. This is a rewarding project because it doesn't cost much (just the rubber seal and some time) and when you notice the lack of rattle you can pat yourself on the back for a job well done. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
