02-15-2011, 09:41 PM | #1 |
35 fuel pump rod
Today I fired my motor, have rebuilt carb,rebuilt fuel pump,and working that by hand it has good suction, have a fuel pump rod 7 7/8" aluminum intake,and when I crank the motor it moves up and down,but it is not reaching the fuel pump arm. I put grease in the cup on the fuel pump arm and the rod is not reaching it. I have 2, 35 motors and noticed one has an early alum. intake on it ( according to pics ) and the one on mine is a later intake also alum. and there is an 1'' difference in the height where the fuel pump mounts. should i use a 8 7/8" rod or just hook up an electric pump. Thanks.
02-15-2011, 09:44 PM | #2 |
Re: 35 fuel pump rod
Use the longer rod. I also have an electric pump for those rare occasions where the truck sits too long and the gas evaporates or leaks out. I do not use it to run with. Mechanical pumps are great (for the most part) just as Henry made them.
02-15-2011, 10:00 PM | #3 |
Thanks, everything you read tells you 7 7/8" for aluminum intake
02-16-2011, 08:06 AM | #4 |
