Old 11-06-2020, 08:09 AM   #1
Ed in Maine
Default A Sensitive Clutch
I recently purchased a 1931 Victoria and I am still trying to get used to the clutch. In other cars I have found that the clutch has more movement at the point that the pressure plate contacts the disc. In this car, as you let out the clutch, the clutch engages very very quickly. When starting out in first gear, you let out the clutch pedal and let it out some more and then suddenly you are fully engaged. So many times I find the car leaps forward almost stalling the engine. What would make a clutch so sensitive? Otherwise the car shifts nicely. The car has about 1500 miles on a drive train rebuild. Ed
Ed in Maine is offline   Reply With Quote
Old 11-06-2020, 08:39 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: A Sensitive Clutch
Have you tried adjusting the linkage for about 1-1 1/2" "free play"??
Paul in CT
Old 11-06-2020, 04:57 PM   #3
Brentwood Bob
Wonder if the throw out needs a little grease on the nose of the transmission?
Brentwood Bob is offline   Reply With Quote
Old 11-06-2020, 07:24 PM   #4
eagle
eagle's Avatar
A rusty clutch can get grabby. Slip it some, it should polish up pretty quick.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 11-07-2020, 02:34 AM   #5
Big hammer
Lack of use makes things stiff, with the car parked use your left leg and push down 2 dozen times on the pedal, slide your left leg out and with your right leg push down 2 dozen times. Whew take a drink of water and now go for a drive to see if it's better!
get a bigger hammer tap done
Old 11-07-2020, 04:46 AM   #6
john charlton
john charlton's Avatar
This can happen if the disc has become contaminated and is "sticky". As Eagle advises slip the clutch to clean up the disc . Put the car in high gear with the handbrake full on . You will not damage the disc as long as you do not slip it for too long . You will soon smell it if it is getting too hot .
John in sunny chill morning Suffolk County England .
john charlton is offline   Reply With Quote
