Old 10-13-2020, 02:01 PM   #1
52 Ford
Default 52 Ford F1 239 Gear oil
I'm looking to change the transmission, rear end and steering box oil. What should i use? Valvoline 85/140 for all three or do each take a different product?
52 Ford is offline   Reply With Quote
Old 10-13-2020, 03:07 PM   #2
adileo
adileo's Avatar
Default Re: 52 Ford F1 239 Gear oil
Here’s what I use in my 39 coupe and 52 F1. Available on Amazon. For both but tranny make sure it’s GL4. Steering I use John Deere cornhead grease
File Type: jpg 6C161FA6-A13C-41CD-8859-4D2D344A280A.jpg (29.8 KB, 14 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-13-2020, 03:33 PM   #3
JSeery
JSeery's Avatar
Kinda depends on what you want to do, GL4 will work in both the transmission and rear axle. Or you can use GL4 in the transmission and GL5 in the rear axle. The steering box depends on how prone it is to leaking. If it is a leaker, Cornhead lube is a good option (JD).
