Old 02-14-2011, 10:35 AM   #1
larry/Texas
Default Wheel bearing race diameter
Can someone tell me the diameter of the wheel bearing race on the rear end bells. I have looked thru all of my books and cannot find it. The only diameter I can find is the roller bearing itself in the vendor books. It is for a 33 tudor. I understand the to dimension is probably the same beginning with the model A.
Thanks for your help.
larry/Texas is offline   Reply With Quote
Old 02-14-2011, 10:48 AM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Wheel bearing race diameter
Here's what I have in my files:
1. Factory drawings for late 32 - 34 show the OD as 2.061" (min), 2.0635" (max).
2. Another person said: 2.0625" diameter nominal
John
Old 02-15-2011, 09:53 AM   #3
Ed Solari
The best info I could find and seems toagree with measurements in the field
Axle bell housing race...factory 2.061 to 2.063 ... max. additional wear allowed is minus 5 mils
Race inside of wheel hub is factory 3.188 to 3.190 max. additional wear allowed is plus 5 mils
Ed
Ed Solari is offline   Reply With Quote
