Old 10-07-2020, 06:28 PM   #1
russcc
Default 59L startup oil pressure at crank speed.
Followed the suggestion of one of the Fordbarner, pouring oil down through output side of the full flow oil system, and removing the plugs. Got oil pressure on cranking right off. Mechanical oil pressure gauge.
This engine is going in the '40 and is 6 volt. Is 20#s oil pressure cranking a 6 volt system satisfactory ?
russcc is offline   Reply With Quote
