Old 10-05-2020, 11:14 AM   #1
Magoo2
Default Front end wobble
My 31 CCPU has a pretty good front end wobble. My first thought was king pin bushings. I checked my wheel bearings and they were adjusted properly. The drivers side was worse so I dismantled that side and removed the king pin.the king pin is fine. When I install the kingpin into the spindle when it’s off the car it seems to fit fine with almost no play. Yet when I place the spindle on the axle there seems to be considerable play. Am I missing something? Axle does not seem to be out of round. Any advice would be appreciated.
Magoo2 is offline   Reply With Quote
Old 10-05-2020, 01:43 PM   #2
GRutter
GRutter's Avatar
Default Re: Front end wobble
"almost no play" can get amplified when on the vehicle.
But another place to look is the fit of the king pin in the axle.
It is not uncommon to find that the bore in the axle that the king pin slides into is worn.
GRutter is offline   Reply With Quote
Old 10-05-2020, 10:01 PM   #3
Synchro909
Synchro909's Avatar
Worn or stretched? I have seen good axles wrecked to the point of needing repair after the cotter pin was done up too tight. That pulls the pin in too far and the taper on it causes the axle eye to stretch.
As for the original question, do a search here - this subject has been discussed fully several times. Overall, there are plenty of posts describing where to look for the problem.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
