Old 10-04-2020, 12:21 AM   #1
HOTRODRON
Default 1929 Ford roadster dash rail brackets
I have the dash rail brackets that go from dash rail to door post but not having any old one to go by anybody out there have a photo that will show how these brackets fit the body thanks for any help Ron
HOTRODRON is offline   Reply With Quote
Old 10-04-2020, 11:34 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 1929 Ford roadster dash rail brackets
If you have the door posts and the rail brackets your about complete for the upper cowl. You also need the bar that crosses over to connect the two posts together. The dash rail trim then covers things up. This link to the HAMB shows the brackets in place but the windshield support stubs and rail bar are broken away from the cowl post but at least you can see the orientation.
https://www.jalopyjournal.com/forum/...-using.761257/
Old 10-07-2020, 10:44 PM   #3
HOTRODRON
Thanks for the help. Ron
