Old 10-01-2020, 04:03 PM   #1
Standing Elk
Default Slight high speed miss
Ok, so my 30 coupe starts very easily and runs smooth until I reach road speed, about 45 mph. At that time it seems to develop a slight miss.I have the more modern points set up installed, timing is set with a light, point gap is set with a dial indicator, spark plug gap is correct and the plugs look good. What should I be checking next? Thanks
Standing Elk is offline   Reply With Quote
Old 10-01-2020, 04:08 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Slight high speed miss
How does it change with changes in fuel adjustment or spark lever settings ?
Old 10-01-2020, 04:26 PM   #3
Tom Endy
Tom Endy's Avatar
If you have a modern wireless lower plate installed in the distributor check to see if there is a burn mark on the slider at the position you have the spark advance set to when traveling at 45 mph.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 10-01-2020, 04:32 PM   #4
Standing Elk
The GAV nor the spark lever position seem to have any effect on it. When I say "slight" miss I mean you really have to pay attention to notice it but it is there.
Old 10-01-2020, 04:33 PM   #5
Standing Elk
Thanks I will have a look for that. What would cause the burn mark if it is there?
Old 10-01-2020, 04:58 PM   #6
Big hammer
Loosen your gas cap and go for a drive. I had a slight miss at or above 55, I removed the cap and then no miss, even up to 70, the cruise control then said SO DOWN ! Guess who that was :-)
get a bigger hammer tap done
Old 10-01-2020, 05:08 PM   #7
Patrick L.
Patrick L.'s Avatar
Tom made a great point. The wireless plates are kinda famous for that. They tend to lose contact. A wired plate or adding a wire will correct that.
Old 10-02-2020, 07:29 AM   #8
eagle
eagle's Avatar
Put some marvel mystery oil in the gas. ATF works too.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 10-02-2020, 07:33 AM   #9
30 Closed Cab PU
X2. Personal experience, had Nu Rex wireless plates, after a while had some odd issues including the original poster's issue. Spent weeks tracking it down. Tried a jumper for troubleshooting which cured the issues. Went back to non wireless, no more problems.
30 Closed Cab PU is offline   Reply With Quote
Old 10-02-2020, 09:21 AM   #10
GRutter
GRutter's Avatar
Check your points. Open them up slightly.
GRutter is offline   Reply With Quote
Old 10-02-2020, 10:14 AM   #11
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Check ferrule at end of fuel line. Must right at end of tube. Tube hits screen and restricts flow.
Jacksonlll is offline   Reply With Quote
Old 10-02-2020, 10:17 AM   #12
chap52
chap52's Avatar
"Slight high speed miss", same thing my cardiologist told me... HUH!
Couldn't resist... Chap
chap52 is offline   Reply With Quote
Old 10-02-2020, 01:05 PM   #13
Jim Brierley
Close the plug gap slightly, say to .025", and go for a test drive. This will tell you if it a weak spark, or not. I sincerely doubt it is a fuel problem. Good luck!
Jim Brierley is offline   Reply With Quote
