Old 09-30-2020, 02:19 PM   #1
1930-Pickup
Default Oil-Filled Condenser Mounting Orientation, Mallory 'Trashcan'
I picked up this large NOS Mallory 'trashcan' type oil-filled condenser.
By all indications, this will be the last condenser this Model A will ever have.
I intend to connect it at the ignition coil, and mount it behind the firewall.
Being oil-filled, I was wondering if there is a mounting orientation requirement.
Oil-filled ignition coils (transformers) have a mounting orientation requirement, and maybe capacitors do too? When I google this question, I get a wide range of answers, from "no orientation requirements" to "orientation is critical". Ah, the internet
Is someone familiar with oil-filled caps? Hoping to hear from someone in the industry (or is very experienced) who has knowledge regarding Design Intent and Good Servicing Practices.
Construction:
Non-polarized terminals (+ and Grd).
0.25MF
1500 VDC
Can is not grounded.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-30-2020, 06:39 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Oil-Filled Condenser Mounting Orientation, Mallory 'Trashcan'
I've replaced a bunch of motor start capacitors that blew all their oil out. They were made to start a motor turning on AC power so they generally don't have a very long duty cycle. It may last a long time and it may not. Nothing electrical lasts forever.
Old 10-01-2020, 08:03 AM   #3
30 Closed Cab PU
Try calling Mallory or pose your question if they have a website, or one of their distributors.
30 Closed Cab PU is offline   Reply With Quote
Old 10-01-2020, 08:15 AM   #4
jetmek
Dont know what your photo is but Thats not like any of the old mallory condensors ive run across And to best of my knowledge they weren't oil filled. Ive seen many split open from age. No oil comes out
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 10-01-2020, 10:14 AM   #5
katy
katy's Avatar
If'n in doubt, mount it terminals up.
Old 10-01-2020, 11:29 AM   #6
midgetracer
midgetracer's Avatar
Mallory is owned now by a large automotive conglomerate and calling customer service gets you no help. Lucky to only get a price.
midgetracer is offline   Reply With Quote
Old 10-01-2020, 11:35 AM   #7
Jim Brierley
Coils are mounted so the terminals are submerged in oil, I would assume a condenser would be the same???
Jim Brierley is offline   Reply With Quote
Old 10-01-2020, 06:52 PM   #8
Pete
I have run them in all positions and they never leaked.
If it leaks, get rid of it.
Another note, many of that type of old capacitors were filled with oil that had PCB (polychlorinated biphenyl) in it. It won't eat your hand off but should be well washed off if come in contact with.
Old 10-01-2020, 08:27 PM   #9
1930-Pickup
Many thanks Pete
Old 10-05-2020, 01:11 PM   #10
1930-Pickup
Thanks to those who contributed to this thread
To close out this thread...
The original question was:
"I was wondering if there is a mounting orientation requirement (for oil-filled capacitors)"?
Results:
There were several opinions based on experience, but most of the opinions conflicted with other opinions. These results are similar to a general internet search. There was no definitive answer in this case.
Comments:
None
Old 10-06-2020, 11:14 AM   #11
redmodelt
redmodelt's Avatar
The trash cans type that I have seen look like an old fashion trash can with a large lid and would have been single lead. When I google that description in the title, what I see are non automotive condensers. But if it will work. This photo is of what I would call an automotive type Mallory trashcan;
Old 10-06-2020, 11:23 AM   #12
Purdy Swoft
Purdy Swoft's Avatar
The later Mallory dual point distributors that I use work good with the same condenser that is offered for the later V8 points .
Old 10-06-2020, 04:23 PM   #13
1930-Pickup
When GM first came out with their "alternatively connected" side-terminal battery, many people must have been very confused and rejecting of the entire idea.
Old 10-07-2020, 10:32 PM   #14
redmodelt
redmodelt's Avatar
Have you asked over on HAMB? There might be a better chance of someone knowing over there or on the Early V8 forum if you haven't or ask Bubbas ignition
https://www.fordbarn.com/forum/member.php?u=3183
Old 10-07-2020, 11:46 PM   #15
1930-Pickup
understood
