Old 09-24-2020, 09:10 PM   #1
DBSHELTON
Default 6v Alternator
I converted a GM alternator to 6v positive ground with a kit. Installed it on my 29 Tudor. You have to rev the engine to excite it to charge. Is this common?
DBSHELTON is offline   Reply With Quote
Old 09-24-2020, 09:15 PM   #2
Bill G
Bill G's Avatar
Default Re: 6v Alternator
That's the way mine works.
Bill G is offline   Reply With Quote
Old 09-24-2020, 09:27 PM   #3
alexiskai
alexiskai's Avatar
Mine too, that's normal. You can rev it when you start up, or you can just let the car run off battery for the first few minutes until it kicks in on its own.
Old 09-24-2020, 09:27 PM   #4
Mike Peters
Mike Peters's Avatar
ditto.
Mike Peters is offline   Reply With Quote
Old 09-24-2020, 09:39 PM   #5
McMimmcs
McMimmcs's Avatar
I think that Is the way they have to be excited to start, Certainly no big deal once you realize what you have to do. It becomes instinct! .
McMimmcs is offline   Reply With Quote
Old 09-25-2020, 04:50 AM   #6
DBSHELTON
Thanks, I figured that was the case, just wanted other opinions. The alternator in my other Model A seems to have a lower cut-in point but that may be due to the little-bit smaller pulley.
Old 09-25-2020, 06:49 AM   #7
MrBruce
MrBruce's Avatar
You can buy the smaller pulley from most Model A vendors and it will kick in quicker.
MrBruce is offline   Reply With Quote
Old 09-25-2020, 07:21 AM   #8
DBSHELTON
I have the one available at the Model A parts dealers, but the one on my other alternator is even smaller.
Old 09-25-2020, 08:43 AM   #9
Jim/GA
Jim/GA's Avatar
When you use the small diameter pulleys on an alternator, you will get better belt grip on the pulley, without a lot of belt tension, if you use a fan belt with the little V-notches in it on the inside surface.
Example:
The exact belt you get will depend on the circumference you need for your engine setup. I don't want to quote a belt number and have it be wrong for your car. Work with your parts supplier.
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 09-25-2020, 09:32 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
The alternator needs a small current flow through its field windings to start. The starting current in a modern car occurs when the charging light goes on as the car is started. I have an alternator in my Coupe that does not self start and requires revving the engine. To the contrary, I have a Nu Rex alternator in my Victoria that self starts. So there is a way of making your alternator self start, but I am not sure to do this.
Bob Bidonde
Old 09-25-2020, 10:17 AM   #11
DBSHELTON
I know you can ground the #1 terminal on it momentarily and it will start charging.
Old 09-25-2020, 11:12 AM   #12
VinceBlack
You can add an exciter wire to the 2wire plug-in, no.1 is excite term no.2 is voltage sense. Add a wire to no. 1 run into cab, by momentarily ground wire alt will start charging. Or you can add a resistor inside of alt to help turn on faster. There are several ways that will help.
VinceBlack is offline   Reply With Quote
Old 09-25-2020, 11:28 AM   #13
Y-Blockhead
Y-Blockhead's Avatar
Best I have found is to not worry about it. I just drive slowly up the street and by the time evrything is starting to warm up it is showing a charge.
I now have a PowerGen and it does not have that non-issue. It charges right from the get-go.
Old 09-26-2020, 10:00 AM   #14
rfitzpatrick
And I thought it was notched for cooling !!
You ever consider writing a book -- for those's of less common sence, such as myself?
Example:
.[/QUOTE]
rfitzpatrick is offline   Reply With Quote
Old 09-26-2020, 12:07 PM   #15
Jim/GA
Jim/GA's Avatar
You ever consider writing a book -- for those of less common sense, such as myself?
I'm glad you find my little tips helpful.
I do not plan to write a book. I have been writing "Jim's Tech Tips" monthly for MAFCA for a couple of years now. They include it in a monthly email blast that they send to Members, and in another monthly blast to all of the Chapter newsletter editors, for clubs to put in their newsletters.
If you want to get the email blast each month, send your email address to modelagarth (at) yahoo (dot) com
Jim Cannon
Old 10-12-2020, 02:46 PM   #16
DBSHELTON
I went ahead and installed a momentary switch to ground on the #1 terminal. Now one touch and it is charging. Makes me feel better anyway.
Old 10-13-2020, 12:50 PM   #17
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
So on a similar note, what do you do about the self-exciting regulator that constantly has a parasitic draw on the battery?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-13-2020, 01:06 PM   #18
Mulletwagon
Mulletwagon's Avatar
Example:
Yep, that would be your BX40 or slightly larger BX41. This is known as a cogged belt.
Mulletwagon is offline   Reply With Quote
Old 10-13-2020, 03:10 PM   #19
DBSHELTON
Beats me!
Old 10-13-2020, 05:09 PM   #20
Synchro909
Synchro909's Avatar
I use an isolating switch on the earth side of the battery. There can be no parasitic draw if the battery is not connected.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
