#1 |
I have a stuck valve that we have tried Mystery Oil, tapping on the valve and today removed the intake. The valve will not come down.
Any more ideas. Thanks |
#2 |
Make sure that the cam lobe is on the 'heel'. The valve beside the stuck one should also be open. Keep in mind also, that these valves bend very easily.
#3 |
Try a 50/50 mix of Acetone and Auto trans fluid.
it is cheaper than MMO and you can use a Lot more |
#4 |
![]() Mike |
