#1 |
Who sells correct fitting lug nuts or do I need to find a set of originals? I have a '29 Coupe.
Most re pops I see made today are loose fitting (slightly oversized) on the lug bolt which causes wear on either. The set I have now are like that. I have one or two originals that fit as designed but not a complete set. |
#2 |
I got a set of cad plated ones from Berts and they fit as they should.
#3 |
Thank you. |
#4 |
I see a post about lug nuts once in awhile and it got me to wondering.
Do people ever check closed end lug nuts for bottoming out before they seat on the taper? I have also seen reproduction nuts that did not have the counterbore on the leading edge. |
#5 | |
![]() Quote:
I do not know if people check but Vince Falter has a webpage on the subject. http://www.fordgarage.com/pages/dangerouslugnuts.htm Last edited by Benson; 09-03-2020 at 04:34 PM. |
#6 |
Tom Endy |
#7 |
When I was running stock model A wheels I used to use the large pattern race nuts.
They will compensate for slightly oversize holes in the wheel and still center ok. |
