Old 08-29-2020, 07:07 PM   #1
McMimmcs
McMimmcs's Avatar
Default tutorial or video to adjust a clutch ??
My friend is a modern day mechanic, not a Model A mechanic ! Is there a tutorial for him to watch or follow to adjust my clutch? Thanks in advance.
McMimmcs is offline   Reply With Quote
Old 08-29-2020, 09:35 PM   #2
shew01
shew01's Avatar
Default Re: tutorial or video to adjust a clutch ??
https://youtu.be/miJNZXgRGZA
shew01 is offline   Reply With Quote
Old 08-30-2020, 06:05 AM   #3
shew01
shew01's Avatar
Here is a Ford Barn link too.
https://www.fordbarn.com/forum/showthread.php?t=164307
Old 08-30-2020, 06:16 AM   #4
Patrick L.
Patrick L.'s Avatar
What are you trying to adjust ? Fingers or free=play ?
You friend will know how to adjust the free-play.
Old 08-30-2020, 06:23 AM   #5
McMimmcs
McMimmcs's Avatar
It has gone from no grind to grinding going into all gears.
Old 09-01-2020, 07:13 PM   #6
McMimmcs
McMimmcs's Avatar
Thank you for all the responses! Now it’s up to the mechanic.
Old 09-01-2020, 11:16 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Is the tranny full of oil?
Is the clutch arm intact, no cracks?
Old 09-02-2020, 02:06 AM   #8
McMimmcs
McMimmcs's Avatar
I’ll have the mechanic check, thank you !
Old 09-02-2020, 05:56 AM   #9
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I assume that you realize that the A trans. does not have syncronizers.
Search youtube for How to shift a model a.
Jacksonlll is offline   Reply With Quote
Old 09-02-2020, 06:58 AM   #10
ryanheacox
ryanheacox's Avatar
If it started grinding out of nowhere my bet is that the arm cracked.
ryanheacox is offline   Reply With Quote
