#1 |
Trying to install cam into block, cam is a Kiwi 100 from Tony. Cam bearings were installed at machine shop. Did not have cam when bearings were installed. Oiled bearings and journals for test fit. The cam would not slide in. The journals measures 1.797 and the cam bearing measures 1.794. I know obviously I need to go back to machine shop, any other advice? As always thanks in advance.
