Old 08-21-2020, 07:57 AM   #1
Flop
Default Nu-Rex popout look alike ignition switch
Went to take my 28 leather back out and smoke starts coming out of the dash . Took dash apart nothing was fried but car wouldn’t start . Hot wired the switch and the car instantly starts . Made in China ignition switch let all its magic smoke out . Has anyone used a nu Rex switch ? Seems they are made in Akron Ohio .
Thanks guys !
https://www.nurex.com/pop-out-ignition-switch
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 08-21-2020, 08:30 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Nu-Rex popout look alike ignition switch
I can't say for sure the ones that Snyder's sells are Nu-Rex, but we have used them (the ones Snyder's sells) with no reported issues.
Old 08-21-2020, 09:20 AM   #3
Ruth
It does say in Snyder's catalog that their ignition switch is a "Genuine Nu-Rex".
Which brings up something I wish the vendors would do more often is state who the manufacturer is on a part so I can determine if I want to buy it or not.
There are some good manufacturers and there are some not so good ones that I try to avoid and will return if received.
Nu-Rex makes an ignition switch with an accessory terminal that may be a solution to a question in another thread.
Ruth
Old 08-21-2020, 09:51 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Flop, -good to see you back man!! Post up some pix of what you are working on!!
I would venture a guess the Ammeter is what is faulty. As for the Nu-Rex switch, they are very good quality. You won't go wrong with one of those.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-21-2020, 09:58 AM   #5
w.michael
w.michael's Avatar
I have used the Nu-Rex switch for several years now with no problem. Looks good in the instrument panel, very similar to the original pop-out. I've had problems in the past with several of the cheaper switches; the Nu-Rex is worth the higher price.
Glad to see you posting again, Flop.
W. Michael
w.michael is offline   Reply With Quote
Old 08-21-2020, 10:15 AM   #6
Jim/GA
Jim/GA's Avatar
Yes, the Nu-Rex switch is good. Very well made.
On some old reproduction instrument panels, the back of the switch contacts the gas tank because the shape of the panel is wrong. This is clearly not good.
The Nu-Rex switch has a mounting collar held by a very small set screw. You can loosen the set screw and turn the mounting collar 1/2 turn or 1 turn or whatever you need to have the switch not contact the gas tank, then tighten the set screw back up and carry on. I like this adjustability that is built in.
I also put a couple of strips of electrical tape on the gas tank behind where the switch will mount, as added protection against the switch contacts touching. No one sees the tape.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 08-21-2020, 10:26 AM   #7
Flop
Thanks guys !! Brent working now on our farm house from the 1880s moved out of the city to the country . 7 acres now a 6k sq foot pole building etc etc .Haven’t worked on a car in about a year . Hopefully it will be fun again once I start messing with them again . I was burned out . That’s my 28 leatherback
File Type: jpg 1EBE1BF2-79BB-42B3-9B42-1B75B66AB75F.jpg (89.4 KB, 63 views)
412 867 1659
[email protected]
Old 08-21-2020, 10:29 AM   #8
Flop
Brent ...also does anyone make a good ammeter ?
412 867 1659
[email protected]
Old 08-21-2020, 10:41 AM   #9
Jim/GA
Jim/GA's Avatar
I'm not Brent, but...
Not reproduction. You need to get a restored original.
Thankfully they are available.
Jim Cannon
Old 08-21-2020, 10:51 AM   #10
Flop
Thanks Jim !! I’ll have to start looking for an original !
412 867 1659
[email protected]
Old 08-21-2020, 09:14 PM   #11
SteveB31
SteveB31's Avatar
They are made in Mexico, but work great.
SteveB31 is offline   Reply With Quote
Old 08-21-2020, 10:14 PM   #12
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Flop: nice lookin car
Old 08-22-2020, 06:48 AM   #13
Bob-A
Bob-A's Avatar
Cool Re: Nu-Rex popout look alike ignition switch
On some old reproduction instrument panels, the back of the switch contacts the gas tank because the shape of the panel is wrong. This is clearly not good. Quote from Jim/GA
I switched to one of the uncommon brass made original Ford "A" 30-31 gauge panels. They are shallower then the steel ones and this has caused a lot of problems using the Nu-Rex popout switch. I've taped everything: the back of the switch, the gas tank, etc. I still get a short in the ignition if I tighten the top left gauge panel screw to tight.
Bob-A
Bob-A is offline   Reply With Quote
