Old 08-14-2020, 11:41 AM   #1
vernlee
Default 1952 stuck flathead
I bought a 52 F100 flathead complete engine but froze up , I pulled the heads cylinders and pistons look very good , very clean no carbon , I fought the valve removal for two weeks , finally got them out today what a JOB , put a socket on the crankshaft pulley and pop it freed up turns smooth and easy , I kinda assumed it was the valve train that was hanging everything up , now my question , should I go ahead a pull the oil pan and check everything , or just work on the top end with new valves , seats , springs ect .and go for it ? , motor still had clean oil in the original air cleaner and oil filter , crankcase oil looked good also , no signs of moister or anything , motor had been setting for 25 years , what do you think ?
Vern
vernlee is offline   Reply With Quote
