Old 08-09-2020, 07:43 PM   #1
Ranchero50
Question Custom building vintage style wiring
Hey guys, looking for sources of vintage cloth covered wiring and especially the large rubber heat shrink covers for the eye terminals for my speedster.
I'm going to use a '49ish dash mounted ignition switch and need to do some custom wiring for that and the same era gauge lamps.
Photo so you know what I'm starting with.
Thanks in advance.
Jamie
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 08-09-2020, 07:57 PM   #2
dbaldwi3
dbaldwi3's Avatar
Default Re: Custom building vintage style wiring
E-bay has been my source for the proper cloth wire sold by the foot also the cloth sheathing with the tar coating also sold by the foot. Good luck with the speedster I’m just getting started on mine!
dbaldwi3 is offline   Reply With Quote
Old 08-09-2020, 08:01 PM   #3
CarlG
CarlG's Avatar
Try Sacramento Vintage Ford
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-09-2020, 08:15 PM   #4
GPierce
GPierce's Avatar
The Model A suppliers, Brattons, Snyder’s has it by the foot; $.85
GPierce is offline   Reply With Quote
Old 08-09-2020, 09:24 PM   #5
Jack Shaft
cloth loom with modern wiring,shrink connectors ..
Jack Shaft is offline   Reply With Quote
Old 08-09-2020, 09:48 PM   #6
Aok
Aok's Avatar
When I use to work on 40's-50's mopars I had used rhode island wiring.
http://www.riwire.com
Aok is offline   Reply With Quote
Old 08-10-2020, 12:03 AM   #7
1930-Pickup
Vintage car electrical supplies and harnesses:
https://www.store.ynzyesterdaysparts.com/
Unique vintage car stuff and electrical
https://restorationstuff.com/
1930-Pickup is offline   Reply With Quote
Old 08-10-2020, 04:01 PM   #8
Ranchero50
Thanks for the ideas. I'm actually trying to find the heavy walled insulation that goes around the wire terminal. I assume that it's some type of heat shrink but it has a 1/8" thick wall. Probably should have calle Jeff at Bratton's today but I've been crazy busy at work.
Old 08-10-2020, 04:11 PM   #9
1930-Pickup
Maybe you're thinking of asphalt loom?
They use it on Model A and AA commercial headlight conduits (instead of stainless flex loom like with the cars).
Comes in all sizes though...
Old 08-10-2020, 04:21 PM   #10
Ranchero50
Nah, not the loom. The actual insulation on the terminals like the left side terminals on this dash wiring.
https://www.brattons.com/dash-wire.html
You wouldn't think that it would be this difficult
Old 08-10-2020, 04:25 PM   #11
1930-Pickup
I believe that's heat shrink tubing, but I've never seen it 1/8" thick wall though.
Old 08-10-2020, 04:46 PM   #12
GPierce
GPierce's Avatar
Harbor Freight has a heavy wall heat shrink with an internal glue that melts and seals the joint. Marine heat shrink tubing. I use it on my airplane and Model A connections.
https://www.harborfreight.com/search...hrink%20tubing
It has 42 pieces and 6 different sizes in the box.
File Type: jpg B10A78B7-B88A-4CC8-BBEC-33C0102664EA.jpg (42.8 KB, 19 views)
Old 08-10-2020, 05:18 PM   #13
Ranchero50
I don't think that stuff is thick enough. American autowire has it as part of this ignition switch kit.
https://www.americanautowire.com/sho...ncludes-switch
Old 08-10-2020, 06:11 PM   #14
OLDMANKOHOUT
Sacramento Vintage uses a rubber sleeve that is applied with a 3-prong tool to expand. They can be applied without a tool, just takes longer.
https://www.vintageford.com/sect_veh...=Wiring%20Shop
OLDMANKOHOUT is offline   Reply With Quote
Old 08-10-2020, 08:13 PM   #15
Ranchero50
OK, that's what I'm after. Rubber sleeve makes me think it's just repurposed tubing...
Ironic that I can't find the pics that you posted on their site. PITA but thanks for the info.
Old 08-11-2020, 12:25 PM   #16
Purdy Swoft
Purdy Swoft's Avatar
I use to make my own wiring harnesses . Now that color coded wiring harnesses are offered at a very reasonable price by some of the vendors , I use them . I always used the available headlamp wiring harnesses because I would rather pay the price than make the harness myself .
Old 08-11-2020, 02:12 PM   #17
Jack Shaft
I custom made my harness,used weatherpack connectors in the headlight harness to make removal a snap..heat shrink connectors in wet areas,fuse protected relay operated circuits to reduce switch loads..LED lighting leaves a lot of ampacity, even at night..
Old 08-12-2020, 07:31 PM   #18
Tinbasher
Tinbasher's Avatar
Restoration Supply Co. in California. JP
Tinbasher is offline   Reply With Quote
Old 08-13-2020, 05:17 PM   #19
Ranchero50
I do similar on the modern stuff. This I want to look vintage, '50's at the latest.
Thanks,
Jamie
Old 08-13-2020, 05:40 PM   #20
Jack Shaft
Thanks,
Jamie
good luck
