Old 08-09-2020, 01:19 PM   #1
31pickup650
31pickup650's Avatar
Default U-Joint Inspection for Vibration
https://youtu.be/KGXtCB5AoG8
This seems like way too much side to side play in the u-joint based on what I’ve seen with more modern parts. It is still pretty tight when purely twisting the u-joint.
If this is normal, what’s the next spot to look for a driveline vibration that doesn’t seem to be related to which gear I am in? Something at the rear end or torque tube?
Thanks.
-Noah
1931 Model A Pickup
My Model A : https://www.fordbarn.com/forum/showthread.php?t=173024
31pickup650 is offline   Reply With Quote
Old 08-09-2020, 01:41 PM   #2
Ruth
Default Re: U-Joint Inspection for Vibration
Thanks.
Looks pretty normal to me as long as there is not axial play. Was the retaining bolt tight? There is a bearing in the torque tube just aft of the speedo gear you might check while you are there.
Ruth
Old 08-09-2020, 01:58 PM   #3
31pickup650
Yeah, the nut holding the u-joint was tight. I’ll look at the torque tube bearing next. Thanks.
-Noah
1931 Model A Pickup
Old 08-09-2020, 04:35 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Have you checked your tires and wheels for problems
Another thought is an axle bent at the end, outside the bearing. It would act like a bent wheel.
