Old 08-05-2020, 10:08 AM   #1
CA Victoria
CA Victoria's Avatar
Default Brake drum removal
Does the proper broach cutter to cut the wheel stud have a square end or tapered?
Anyone have a part number for an off the shelf cutter?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 08-05-2020, 11:26 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Brake drum removal
Tapered
Old 08-05-2020, 12:10 PM   #3
KR500
KR500's Avatar
I have had good luck using a 9/16 quality hole saw for removing the bulk of the swaged portion of metal on the brake drum. Studs push out easily after with no enlarging of stud hole in the hub.
KR500 is offline   Reply With Quote
Old 08-06-2020, 09:47 AM   #4
redmodelt
redmodelt's Avatar
Unless you are trying to save the drums for some reason(?), the regular off the shelf flat/square end works just fine. Only cut deep enough to remove the riveted over part of the stud.
