Old 07-25-2020, 11:03 PM   #1
GregLast
GregLast's Avatar
Default Switched Carbs: choke rod doesn't line up
I just picked up a rebuilt Tillotson Model X, and swapped it out with my Model B Zenith. The choke rod doesn't line up right and it's not a smooth pull.
It never really lined up with the zenith, it was off just a little, but now this is out of whack by a lot. I can make it work, but I won't leave it like this for long.
Any suggestions? Is there a difference in intake manifolds?
GregLast is offline   Reply With Quote
Old 07-26-2020, 01:26 AM   #2
Jembow
Jembow's Avatar
Default Re: Switched Carbs: choke rod doesn't line up
Model A & Model B carbs are different and won't line up unless you use the correct manifold.
Jembow is offline   Reply With Quote
Old 07-26-2020, 06:55 AM   #3
ronn
bend the rod- spoil the child........
Old 07-26-2020, 07:57 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
Model B intake manifolds are different .
Old 07-26-2020, 09:10 AM   #5
wmws
Front engine mounts could be shot. Does the crank hole line up?
wmws is offline   Reply With Quote
Old 07-26-2020, 10:13 AM   #6
Bob C
Mikes Affordable has the kit so the choke will line up.
https://www.mikes-afordable.com/product/B9510S.html
Old 07-26-2020, 10:50 AM   #7
Ernie Vitucci
Ernie Vitucci's Avatar
Good Morning...The bolts in the kit have had their shafts turned down a bit in the center so that the carburetor can swivel a little bit and line up. The kit works, if you have a lathe, you can make a couple...Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 07-26-2020, 11:40 AM   #8
Purdy Swoft
The model B carburetor has a larger throat but the bolt pattern is the same as the model A . If the intake manifold runner is enlarged to model B size you will benefit from the larger model B carburetor . If the larger model B intake is used it will cause the carburetor to be at an angle that won't line up with the choke rod . unless the kit above is used . I once cut the flange off of a model B intake , turned it to the correct angle for use on the model A and brazed the flange back in place .
Old 07-26-2020, 12:56 PM   #9
Big hammer
It didn't line up right with the Zenith, why would it line up with the Tilly ?
Maybe the frame is sagging, body blocks bad ? To get by..... removing the rubber grommet inside the car just might work, the choke rod would rattle!
get a bigger hammer tap done
Old 07-26-2020, 01:44 PM   #10
Bob C
Yes.
Old 07-26-2020, 04:30 PM   #11
Purdy Swoft
When the model B intake manifold is used , the position of the carburetor doesn't point in a straight back manner like it would if the model A intake manifold was used . The flange that the carburetor mounts too causes the rear of the carb , where the choke rod connects to be at an angle that doesn't line up with the choke rod .
Old 07-26-2020, 06:58 PM   #12
SteveB31
SteveB31's Avatar
The Model B carburetor was made for a Model B (1932-1934) Ford. It was never used nor designed for a a model A , and it used a flexible choke cable. The Tillotsen you had on your car was actually made to be used on a Model A.
SteveB31 is offline   Reply With Quote
Old 07-26-2020, 08:43 PM   #13
GregLast
GregLast's Avatar
This is actually quite likely. I have found at least one body block crushed, so I'm in the process of getting the body off to address a few things. Once I get everything mounted back up, I'll double check.
Someone else mentioned if the crank hole is lined up. It is, so I'm not too worried there.
Best case scenario, it's the body on the frame wonky, I fix that and the Tilly should line up. I hadn't thought that it could be this.
Thanks guys!
Old 07-26-2020, 09:03 PM   #14
Bob C
Can you post a picture of the intake manifold you have?
Old 07-27-2020, 08:02 AM   #15
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Don’t bend the rod. You can’t turn it with a bend in it.
Jacksonlll is offline   Reply With Quote
Old 07-27-2020, 12:49 PM   #16
Purdy Swoft
No harm meant but I believe that the model B carburetor with a smaller venturi was sold as a replacement for the Zenith one and two carburetors on the model A .
