Old 07-16-2020, 09:35 AM   #1
mrraford
Default Rumble Lid and Hinge installation 68C
Good morning all!
Does anybody here know of a treatise on rumble lid assembly? I need some guidance. I have installed my (probably) original hinges onto my reproduction (new) rumble lid and am struggling with getting the hinge install. The lid fits the body opening but the hinges are about an inch and a half away from the brackets.
This is a 68C so all things are attached to a wooden subframe and attachment space is an issue.
I need to tap into some experience on the install for this one. Thanks in advance.
mrraford is offline   Reply With Quote
Old 07-16-2020, 01:05 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Rumble Lid and Hinge installation 68C
This link has a pretty good run down on hinges and deck lids that may answer your questions. It seems the repro hinges don't work well due to shrinkage of the product during casting and the repro deck lids are made to fit the repro hinges and not the originals.
https://sites.google.com/site/cabrio...e-seat-and-lid
Old 07-16-2020, 06:03 PM   #3
d.
rotorwrench has it right...
>> original deck lid... use original hinges.
>>repro deck lid... use repro hinges.
d. is offline   Reply With Quote
Old 07-16-2020, 06:05 PM   #4
Oldbluoval
Oldbluoval's Avatar
Often you have to tweak the hinges (bend) in or out to align well
But repo hinges will break if you stress them
Oldbluoval is online now   Reply With Quote
Old 07-16-2020, 06:36 PM   #5
jw hash
jw hash's Avatar
keep in mind too, all of the Model A Cabriolet`s rumble and panels are the same as the 29 coupes except the lid itself. so original hinges are easy to come by. hopefully you have the correct rumble hinge brackets and as Bill said you can tweak the original hinges.
jw hash is offline   Reply With Quote
Old 07-16-2020, 08:46 PM   #6
Jack Shaft
you can run up your own if your not going for fine point..
Jack Shaft is offline   Reply With Quote
Old 07-17-2020, 11:18 AM   #7
mrraford
Thank you for the information. I suspected the original vs repo nature of the parts was a factor. Great pictures. Thanks again.
If it isn't hot enough to bake cookies in the garage this weekend, I'll investigate using this info.
