#1 |
no lights, no horn. question the business end of the harness is a round disc with 9 terminals. those terminals are in 3 groups of three looking at the back side it looks like each set is tied together. so if i put one wire from an ohm meter on one wire in the back should i get continuity when i put the other wire from the meter on each of the nine terminals on the front?
#2 |
No. The current is directed to the individual contacts via the three point-shaped brass contact plate that you can turn from the steering wheel.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
#3 |
Ok are you saying I should not get continuity on all nine front terminal s? Thanks for the response.
#4 |
The three terminals for the tail light are hooked together and the three terminals for the battery are hooked together. The three for the headlights are not.
#5 |
No lights or horn means the two yellow wires are open at the cutout terminal (running). If not running, could be open at the firewall or ammeter (or fuse).
#6 |
#7 |
Like always good helpful info.
Thanks |
