Old 07-06-2020, 08:10 AM   #1
marko39
Default 39 fan
After finnaly getting an engine in my 39 deluxe I am sorting things out. Cooling fan does not seem correct for this engine as it is barely 1/2 inch from radiator. It measures 4 1/2 inches from outside of hub to mounting flange and is 15 3/4 inches in diameter. I don't think this is a 91a fan but don't know. Does anyone know the correct dimensions of a 91a fan? Fan in question came off a 38 engine with short crank snout. Thanks, Mark
marko39 is offline   Reply With Quote
Old 07-06-2020, 09:26 AM   #2
Kube
Kube's Avatar
Default Re: 39 fan
It sounds as if you have the 39 / 40 Mercury fan. At first glance it appears identical to a 39/40 Ford fan. Upon closer inspection, you'll note the distance from the mounting surface to the hub is longer on the merc.
Fortunately for you, 39/40 fans are all over the place and reasonable.
Old 07-06-2020, 10:49 AM   #3
40larry
Default Re: 39 fan
According to the 1939 t0 1948 Mercury Chassis Parts Catalogue the Mercury used the same Ford fan assembly 91A-8600 for 1939 and 1940. The 1941 Mercury fan has a longer snout and only fits the 1941 Mercury. My experience with 1939 and 1940 Fords is that the fan to radiator clearance will vary on each car by a small amount. One half inch clearance is a little tight but changing the fan will not help. You only need about 1/4 inch more clearance. I would try getting the radiator to go a little forward to get the needed clearance to replace the fan belt.
40larry
40larry is offline   Reply With Quote
Old 07-06-2020, 10:58 AM   #4
40larry
Default Re: 39 fan
40larry
Old 07-06-2020, 11:46 AM   #5
marko39
Default Re: 39 fan
Thanks, the fan is crank mouted and radiator has little play. Fan kissed it on bottom. Per green bible fan should be 3.75 in. about 3 /4 inch shorter than the one I have. Thats why I was asking about a correct 91a fan. Mark
Old 07-06-2020, 11:54 AM   #6
40larry
Default Re: 39 fan
You might have the wrong fan. It is supposed to be 16.75 inches diameter. Can you post a photo of your fan.
40larry
Old 07-06-2020, 12:46 PM   #7
marko39
Default Re: 39 fan
40larry
This fan is 15 3/4 diameter which is another clue to it being incorrect. Sorry, can't post photo .
Old 07-06-2020, 01:59 PM   #8
Kube
Kube's Avatar
Default Re: 39 fan
Marko,
Here's a photo of a proper 85/95 hp '39 Deluxe / '40 (all) cooling fan.
If you had simply measured across two opposing blades, you'd come up with something near 15 3/4".
The hub to mating surface distance is in fact 3 3/4" for the Ford.
Be careful when using a parts book to determine absolute correctness. One must always remember that the parts listed are service parts that will fit and function but not necessarily be correct.
Old 07-07-2020, 06:52 AM   #9
marko39
Default Re: 39 fan
Marko,
Thanks, Mike. that is the fan i need. i am checking on some now. Mark
Old 07-07-2020, 07:33 AM   #10
Kube
Kube's Avatar
Default Re: 39 fan
Private message sent
