Old 07-03-2020, 09:18 PM   #1
31Abone
31Abone's Avatar
Default Rocky mountain under drive ? what is it ?
A "T" man here said it was not Model T or model A ? anyone know what it is ?
31Abone is offline   Reply With Quote
Old 07-04-2020, 04:32 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Rocky mountain under drive ? what is it ?
The guy was sort of right. That actually was made for a TT truck - read this thread.
http://www.mtfca.com/discus/messages...tml?1231914641
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-04-2020, 10:21 AM   #3
31Abone
31Abone's Avatar
Great info..should have posted to T forum..pic that i found on search
Old 07-04-2020, 10:49 AM   #4
rotorwrench
rotorwrench's Avatar
Most of these type units function and a two speed rear axle would. Some are under drives to allow for lower gearing ratios for pulling heavy loads. Some units like this are both an under drive and an over drive for a three way split of gears giving nine possible speeds forward and three in reverse.
Since that one is advertised as a six speed then I'd be relatively certain that it is just an under drive box with an under drive ratio and a one to one ratio only. This way a person can split shift in all three forward gears giving 6 ratios usable in forward motion and two ratios in reverse.
Units were manufactured to work with the Model AA trucks as well.
Old 07-04-2020, 11:04 AM   #5
Bob C
The Model T only had a two speed transmission so the Rocky Mountain
would have to be a three speed to get six speeds. The ad shows
three speeds in reverse.
Bob C is online now   Reply With Quote
Old 07-04-2020, 11:15 AM   #6
31Abone
31Abone's Avatar
more info picture
File Type: jpg rocky mtn transmission instructions.jpg (44.8 KB, 46 views)
Old 07-05-2020, 11:25 AM   #7
rotorwrench
Your right. It's an over under then. I keep thinking about my Grandad's old IHC Six Speed Specials. He never had Model TT trucks.
