Old 06-19-2020, 10:47 AM   #1
einstein
Question Running Rich
I have a 1990 5.0 HO EFI in my 40 ford it smells like it is running very rich ant ideas to solve this?
einstein is offline   Reply With Quote
Old 06-19-2020, 03:43 PM   #2
scicala
scicala's Avatar
Default Re: Running Rich
Maybe no manifold vacuum to the fuel pressure regulator, or leaking internally (regulator). Possible the vacuum hose was never on the regulator, or fell off from poor fit ?
Sal
Old 06-19-2020, 05:11 PM   #3
cadillac512
cadillac512's Avatar
Also, check the MAP sensor for a leaky hose or a bad sensor. Fords rely heavily on the MAP to control mixture. You need a Hertz (cycles pr second) sensor to test it...it varies frequency rather than voltage.
A proper Flathead doesn't have this trouble....(Flathead content to meet forum rules,LOL!)
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-19-2020, 05:58 PM   #4
51woodie
51woodie's Avatar
Could be the float level is set too high. Missing or bad oxy sensor? Can you connect a scan tool?
51woodie is offline   Reply With Quote
Old 06-19-2020, 06:37 PM   #5
deuce_roadster
deuce_roadster's Avatar
Maybe install a flathead!
Old 06-19-2020, 08:17 PM   #6
tubman
tubman's Avatar
I don't think this is the best place to ask this question, Maybe the "Ford Truck Forum" or maybe a late Mustang forum?
Old 06-20-2020, 01:37 PM   #7
solidaxle
solidaxle's Avatar
If you own a spark plug socket? I would start there. Smellameters are not very accurate.
solidaxle is offline   Reply With Quote
Old 06-20-2020, 03:18 PM   #8
Mart
Mart's Avatar
Some background would help. For instance, has this been running fine for years and has suddenly started misbehaving, or is it a fresh build and first start? Have you made any changes lately? that sort of info.
I had a fuel injected car once that wouldn't run from first start It turned out the lamda sensors were cross wired. The effect was that the left bank got leaner and the right bank got richer in a vicious circle.
That is why I am asking about how long it has been running.
You must understand this is not the normal fodder on this forum so you might struggle to get guidance.
Mart.
