Old 06-12-2020, 03:18 PM   #1
29Blue
Default Radiator Hoses
In the process of changing water pump on my mostly original 29 Tudor and also want to change the old rad hoses. The upper hose measures 9'' long and shorter lower hoses are 4" long. Vendors show a 6 1/4" and 2 3/4" for a 29. The hoses for 30-31 are listed as 9" and 4". I checked Macs,Brattons,Snyders and Mikes.They all were the same. How come? Thanks, Bob
29Blue is offline   Reply With Quote
Old 06-12-2020, 03:25 PM   #2
frank55a
Default Re: Radiator Hoses
The 29 radiator is a couple inches shorter than the 30/31 radiator. Therefore you need the shorter hoses. At some point someone put a set of 30/31 hoses on your 29.
frank55a is offline   Reply With Quote
Old 06-12-2020, 03:45 PM   #3
29Blue
That's what I thought but it doesn't look like a 6" hose would fit being too short. Shorter lower hoses also look like they would be too short. Maybe with hoses off it will look different? Thanks,Bob
Old 06-12-2020, 04:32 PM   #4
Dean Lemoine
Dean Lemoine's Avatar
I bought a set of black hoses with the red stripe from Mike’s yesterday. I had to cut about 3/4 of an inch from the top hose. Other than that, they fit great on my’29 Tudor. I talked to Eric at Mike’s.
Dean Lemoine is offline   Reply With Quote
Old 06-12-2020, 05:00 PM   #5
29Blue
What hoses did you get from Mikes. Did you cut 3/4" off the 6 1/4" hose or the longer one for 30-31.
Old 06-12-2020, 05:13 PM   #6
ronn
Mikes always has a great deal on the hoses......
bought 5 sets a few yrs back and always at the ready!
Old 06-12-2020, 05:40 PM   #7
Dean Lemoine
The top hose was originally 7 1/4 inches long, I cut 3/4 of an inch from it. Both bottom hoses are 3 1/2 inches long ( I didn’t cut these). This is a ‘29 Tudor and a new Brassworks radiator.
Old 06-12-2020, 10:39 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I would verify radiator, front crossmember( 28/39 round radiator holes an flat mount, 30/31 oblong mounting holes and a dropped mounting pad). The outlet on top of the head was different between years as well.
