Old 06-08-2020, 12:11 PM   #1
30-9
Default Coil wire
Hi Gents
What size wire best from resistor to coil?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 06-08-2020, 12:40 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Coil wire
Originally Posted by 30-9 View Post
Hi Gents
Not trying to be "cute" here, but you can NEVER go too big on wire size. #14 or #12 stranded ought to get ya down the road! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-08-2020, 01:41 PM   #3
30-9
TY DD and I do think your pretty cute
Thanks - 30-9
1939, 1940
Old 06-08-2020, 06:31 PM   #4
30-9
Little more help needed. I can’t determine the color of wire going to the coil. Under dash on resistor it’s clean and easy to see wire color. Looking at the wiring diagram... am I correct it’s the solid red wire going from resistor to coil?
Oh it’s 39 coupe��
Thanks - 30-9
1939, 1940
Old 06-08-2020, 07:32 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Oh it’s 39 coupe��
Assuming you're talking '39 or '40 Ford, I concur.....RED between resistor and coil! DD
T5 W/TORQUE TUBE
Old 06-08-2020, 07:34 PM   #6
30-9
I thank you again Sir!
Thanks - 30-9
1939, 1940
Old 06-10-2020, 07:15 PM   #7
30-9
Sorry for the lag. As mentioned, I am suspect of a bad coil wire. You see any issue with: Running a new #14 wire right on top of existing wire?
Thanks - 30-9
1939, 1940
Old 06-10-2020, 08:06 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Don't see a thing wrong with that. But before you go to all that trouble though, have you tried ohm'ing that existing wire to see if it in fact shows continuity (conductivity), or if it shows an "open" (non-conductive)? DD
T5 W/TORQUE TUBE
Old 06-11-2020, 08:06 AM   #9
30-9
DD thanks. The problem is intermittent.
Thanks - 30-9
1939, 1940
Old 06-11-2020, 11:38 AM   #10
JayChicago
JayChicago's Avatar
While a broken wire could produce an intermittent problem, I suspect source is more likely the ignition switch or a loose connection. I have heard of guys playing with the ignition switch toggle to make continuity to get home.
JayChicago is offline   Reply With Quote
Old 06-11-2020, 12:06 PM   #11
30-9
Thanks and I agree with your logic.
I’ve already replaced the ignition switch. Got new Skip coil with a tested condenser from him. Also rebuilt distro from Bubba.
I’m fairly sure it’s not fuel. I have had fuel tank professionally cleaned and replaced all of the fuel lines.
This wire is the last item on my list of possibilities.
Thanks - 30-9
1939, 1940
Old 06-11-2020, 02:37 PM   #12
JayChicago
JayChicago's Avatar
Have you done the basic fuel vs. spark test?
When the intermittent problem is occurring, look down the throat of carb and move the throttle to see a squirt of fuel. If you see it, you know there fuel in the carb.
When intermittent problem is occurring, remove a spark plug lead and hold end near a ground, to see if you are getting spark there.
Old 06-11-2020, 03:12 PM   #13
30-9
Yes to both. The issue only seems to happen when driving/cruising 45-50 mph. Car will buck. If I floor it it seems to go away. If I stop at light it idles fine.
I added the #14 from resistor to coil. I’m really hoping it resolves the issue.
Thanks - 30-9
1939, 1940
Old 06-11-2020, 03:38 PM   #14
JayChicago
JayChicago's Avatar
OK. If only happens when at high speed, the plot thickens. "45-50 mph. Car will buck"
The only thing that comes to my mind is possibly a sticking valve. Here is an easy-to-do try: Marvel Mystery Oil. When I was dealing with a sticky valve, MMM in the oil did nothing. But MMM in the fuel cured the problem on the first drive. I was a skeptic of snake oil fixes, but now I'm a born-again believer. Sometimes (rarely) a chemical treatment can actually fix a problem.
Let us know when you find the cure so we can all learn from others.
Old 06-11-2020, 10:55 PM   #15
Karl
Karl's Avatar
Having just spent the last 5 months trying to fix a similar problem make sure that the fuel bowl on the pump is not sucking air that was what mine was doing and exactly the same symptoms
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 06-12-2020, 06:57 AM   #16
30-9
Thanks for that, but I removed mechanical pump. Only run airtex electric pump.
I’ll buy a bottle of Marvel mystery oil for gas. Can’t hurt
Thanks - 30-9
1939, 1940
Old 06-12-2020, 02:55 PM   #17
rotorwrench
rotorwrench's Avatar
It was likely a 16 gauge wire back in 39. The old cloth covered stuff doesn't hold color well after 10-years or so they all look like straw unless they were covered with loom, tape, or something of that nature.
Old 06-12-2020, 03:48 PM   #18
JSeery
JSeery's Avatar
One of the drawings calls out #16 on later years.
