Old 06-05-2020, 08:31 AM   #1
Hoop
Hoop's Avatar
Default Helmet Distributor on the HAMB
Thought this was interesting.
https://www.jalopyjournal.com/forum/...eeded.1195035/
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 06-05-2020, 08:50 AM   #2
35fordtn
35fordtn's Avatar
Default Re: Helmet Distributor on the HAMB
Those are very clearly Dennis carpenter points
35fordtn is offline   Reply With Quote
Old 06-05-2020, 01:39 PM   #3
Will D
Will D's Avatar
Had a similar issue with some points I got awhile back from standard. They did not align even after bending back to 90...had to add a spacer below the point block, then sand the top of the block to allow brass washer and c-pin to fit back in while allowing the block to pivot freely. Had more time than money...
Will D is offline   Reply With Quote
