Old 05-26-2020, 04:47 PM   #1
txmike
Default Speedometer cable question
I purchased a new speedometer cable from Bratton's and it comes with part A-17260-A and states on the package: NOTE: Some early transmission drive gears with deep hole will required this spacer be dropped in first.
No diagrams, no other instructions.
How do I tell if I need this part? Dropped in where?
Thanks
txmike is offline   Reply With Quote
Old 05-26-2020, 04:59 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Speedometer cable question
Ck the ends of your old cable...................
Paul in CT
Old 05-26-2020, 05:43 PM   #3
burner31
burner31's Avatar
On the end/bottom of your cable and then into the drive gear.
Also: txmike----What year/model you driving?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 05-26-2020, 07:04 PM   #4
chrs1961815
chrs1961815's Avatar
If you do not have an early car, you should not have to worry about it unless it was changed how somehow but usually they don't use rare parts.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 05-26-2020, 07:36 PM   #5
txmike
I guess that would help 1929 Coupe, by engine serial number made in Oct 29
Old 05-26-2020, 10:19 PM   #6
Bill G
Bill G's Avatar
October 29 is not generally considered to be an early car. You are probably good to use the new speedo cable as is.
Bill G is offline   Reply With Quote
