Old 05-12-2020, 07:05 PM   #1
History
History's Avatar
Default Windshield frame gasket
I'm talking about the gasket between the windshield frame and cab. I got one of the sides out but am wondering what's the best way to get the bottom out??
I took a small flat screw driver and used it to pry open the channel for the side and it worked well. It looks like when new it was installed and the channel squeezed to hold it in place. Is that correct??
Should I use any lubricant to slide the new gasket in and if so what kind? It's a 30 sport coupe and I'm guessing it's the same as any enclosed cab model a??
Thanks in advance.
History is offline   Reply With Quote
Old 05-12-2020, 07:56 PM   #2
vic
Default Re: Windshield frame gasket
I recently installed a new gasket and had to open the channel a touch to get the old one out.To make installing the new one slide easily I sprayed it with a XL Silicone Spray....it states on the can that its ok with rubber .
vic is offline   Reply With Quote
Old 05-13-2020, 09:02 AM   #3
Big hammer
Soap and water would be my choice, used a little spit on bike handle bar grips over 50 years ago when I was assembling bikes for dad, the spit would let the grips slide on and then dry and the grips would stay on without slipping off!
get a bigger hammer tap done
