Old 05-07-2020, 07:34 PM   #1
shew01
shew01's Avatar
Default Horn Cleaning
I have the back of the horn off because I’m replacing my radiator. While it’s apart, I’m wondering if I should clean up the rotor or commutator.
Les Andrews 1-196 says you can clean the rotor with a scotch pad, if you totally disassemble the horn and put the shaft in a drill. I’d rather not take the horn apart because it kind of works. It makes a noise, but not a nice ahooga sound.
Is it possible to clean the rotor or commutator while it is still in the car?
shew01 is offline   Reply With Quote
Old 05-07-2020, 08:21 PM   #2
30ccpickup
30ccpickup's Avatar
Default Re: Horn Cleaning
This may help http://modelabasics.com/horn.htm
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 05-08-2020, 04:25 AM   #3
shew01
shew01's Avatar
Since the makes a sound, I hesitate to take it apart. Would it help to brighten the rotor or commutator while the horn is still in the car? If so, what would be effective to clean the rotor or commutator while it is in the car?
Old 05-08-2020, 05:43 AM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
If you can, back off on the adjustment until it spins with no sound. Oil it and let it get up to speed for a bit. That motor needs to run. After the motor sounds strong, readjust it to a good ahooga sound. I find this helps for a while. If you get a horn to sound good. leave it alone.
Jacksonlll is offline   Reply With Quote
Old 05-08-2020, 05:53 AM   #5
1crosscut
1crosscut's Avatar
Hold some fine grade sand paper against the commutator while the horn is spinning to clean it up. Usually makes a world of difference.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-08-2020, 03:28 PM   #6
Jacksonlll
Jacksonlll's Avatar
I recently took a horn apart and found it all welded together. The motor frame was welded to the body where there should be screws and the cage was spot welded so you could not get the armature out. Did they make some after market horns like this?
Old 05-08-2020, 03:30 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
I just wipe with rag, usually just before parade, oil bearings every couple years
Old 05-08-2020, 09:05 PM   #8
David R.
Note to self: use earplugs next time you do this.
I cleaned mine with electrical contact cleaner, oiled bearings and gently held a small folded square of 400 grit against commutator while it’s turning. Sounds much better now.
David R. is offline   Reply With Quote
Old 05-09-2020, 09:09 AM   #9
wmws
Yes my horn is that way. Very difficult to work on and tune. But it was cheep.
wmws is offline   Reply With Quote
Old 05-10-2020, 08:00 AM   #10
old31
Maybe an old JC Whitney horn?
