Old 05-04-2020, 07:13 PM   #1
Johnny Nitro
Johnny Nitro's Avatar
Default Clutch release arm pin removal
Well, it finally happened. Was heading home with my best lady last night, and began to have trouble getting into first at stops. Was pretty bad by the time we made it into the garage. Took a look today hoping I just needed to adjust the pedal, but saw the infamous crack at the bottom of the clutch release arm.
I have a spare from an old bellhousing, but ordered the modern, stronger version from my favorite vendor, anyway.
Now, my question:
How do I remove the pin from the shaft? It doesn’t seem obvious if there is a taper, and it doesn’t seem peened.
I did a couple searches here, as I’m sure this has been covered, but could not find a direct answer to this point.
Thanks for your help!
Johnny Nitro is offline   Reply With Quote
Old 05-04-2020, 07:27 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Clutch release arm pin removal
If you can see both holes one may be a bit larger and or smaller. Easy tap and it should come right out. I too went with the more robust arm. Love it.
Tacoma Bob is offline   Reply With Quote
Old 05-04-2020, 07:33 PM   #3
Mike Peters
Mike Peters's Avatar
We've done a couple here and found that an air chisel with a punch bit will walk that pin right out from the bottom.
Mike Peters is offline   Reply With Quote
Old 05-04-2020, 10:20 PM   #4
PalAl
PalAl's Avatar
I hate to instill fear but here is my story.... several Club members had your same trouble, that prompted other members to get it before it gets you (change it before it breaks).
That was me "Fix it till ya break it"..LOL My pin was stuck with a capital S! I tapped it, pounded it, heated it and hit it harder, that's when it happened...... a clink-ping in the bell housing! Not a good sound! I slowly turned the clutch arm and it was very free, in fact so free it turned 360 deg! We all know "it should not outta be doing that" I then slid the shaft completely out of the bell housing. The next day I started pulling my engine.
Not sure why it happened but that's my story. Pictures show what I found in the bell housing. Fork, woodruff key and pin.
So Johnny Nitro go easy..........................
PalAl is offline   Reply With Quote
Old 05-04-2020, 11:49 PM   #5
old31
Now that is what you call a bad garage day. Wow.
Old 05-05-2020, 01:08 AM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If it doesn’t want to move, you could drill it, assuming you have the angle access.
Old 05-05-2020, 01:29 AM   #7
Johnny Nitro
Thanks for the warning, PalAl!
I always prepare for a job to take longer, and cost more than i originally plan. Case in point: I already broke my throwout bearing return spring while I was monkeying around with everything. Ordered two to be safe when I ordered the new arm!
Mike,
The air chisel idea sounds toot sweet!
Old 05-05-2020, 09:25 AM   #8
1931 flamingo
1931 flamingo's Avatar
I haven't encountered the saying "toot sweet" in a loooong time !!
Paul in CT
Old 05-05-2020, 10:04 AM   #9
Speedyal
Hello,
I had this happen to me . Yes the pin is tapered if you look at it should be able to see one end of pin is bigger diameter then other . Should be able to just use punch and hammer to remove pin , I at least was able too
Speedyal is offline   Reply With Quote
Old 05-05-2020, 10:06 AM   #10
The Master Cylinder
The Master Cylinder's Avatar
The repro pin more than likely will be too big to fit in the hole. I had to massage the diameter a might to get it in all the way. I ordered a spare of those also.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-05-2020, 06:19 PM   #11
Johnny Nitro
I hope that’s the case, actually. I’m not having any luck hammering it out, and may have to resort to drilling. In that case I may need a slightly larger pin.
Old 05-06-2020, 10:16 PM   #12
CWPASADENA
CWPASADENA's Avatar
Instead of a pin, I use good quality grade 8 bolt with the shank, unthreaded, portion of the bolt long enough so all the threads are exposed and no threads are bearing on the lever or shaft. I use a lock nut and cut off any excess threads.
This makes it a lot easier if a repair at a later date is necessary.
I also use a grade 8 bolt for the clutch fork.
I have been doing this for a very many years an many old Fords with no failures.
Chris W.
CWPASADENA is offline   Reply With Quote
