05-03-2020, 01:36 PM | #1 |
29 Tudor front rubber mat fitting question
I purchased a new front rubber mat from Bratton's and I have some questions as to how I am going to get it to fit properly into the car.
I temporarily installed the mat into the car. The first thing that I noticed was that the mat did not move forward enough to have the holes in the mat match up to the floor mat snap studs. The mat fits tightly against the transmission shift tower so there is no way to move the mat forward. So my main question is : Do I trim the trans tower hole in the mat or do I get a big crowbar and move the engine/trans forward??? Any help is appreciated.
Why is there never enough time to do it right, but always enough time to do it over!!! |
05-03-2020, 04:10 PM | #2 |
Re: 29 Tudor front rubber mat fitting question
Well that sucks! I would send it back and tell them to send you one that fits correctly. You should not have to cut anything if those things were made correctly in the first place.
At least you got mat studs in your car...my February 1929 Tudor has none what so ever anywhere and do not think it ever did. Pluck |
05-03-2020, 05:27 PM | #3 |
Move the body forward.
05-25-2020, 02:26 PM | #4 |
My front mat had exactly the same issues. The problem was both the hole for the shift tower and the E-brake handle. I got mine from Snyders, so I suspect Snyders and Brattons must source them from the same place. I carefully used a straight razor blade and elongated both the shifter and the e-brake holes. It fits better, but still not exact. I don't know what to suspect the issue is. My car has had the engine and transmission out three times since I owned the car. But, there just isn't anything that would have that much variability in putting the engine + tranny back in. A second thing could be that I have Float a motor mounts. Still, the front mount is the original style and if the FAMs were off, then the front would not fit well, so it can't be the FAMs causing the problem. I guess I have to go with (c) which is that the manufacturer of the mat is off a skosh.
I agree with Pluck, we shouldn't have to do this, but isn't it kind of common with just about any repop part? It's now the 25th and your original post was 5/3, did you "adjust" accordingly? another part of the mat that is off on mine is around the steering column and pedal plates. |
05-26-2020, 09:56 AM | #5 |
Bill,
Are you saying that if you were to use original rear motor mounts that the front of the engine would not fit well even with the original front motor mount?? Pluck |
05-26-2020, 10:57 AM | #6 |
