Old 04-30-2020, 11:18 AM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Oil Pump Pickup
Take a look at the new oil pump pickup on the left compared to original on the right. The pickup tube is shorter on the new one , I’m somewhat reluctant to use it ..Thoughts ??
File Type: jpg D1C2701E-45C5-4434-8CA8-08E6F2E1FD8F.jpg (47.6 KB, 75 views)
Ken/Alabama is offline   Reply With Quote
Old 04-30-2020, 11:50 AM   #2
cobbie
Default Re: Oil Pump Pickup
Why would you not use a Original Ford part over a repop. Just my 2 cents.
Cobbie
cobbie is offline   Reply With Quote
Old 04-30-2020, 12:17 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
Typical import junk. The last tube cut was to short so they went ahead and used it anyway when welding everything together. Send it back its junk the tube needs to be longer so the siphon effect works correctly in the cup.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 04-30-2020, 01:21 PM   #4
Ken/Alabama
Cobbie
That particular original one went in another engine.
Old 04-30-2020, 05:11 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
I would surely use the original one - or I would weld an 'extension' on the repop one.
Old 05-01-2020, 10:00 AM   #6
cdan34
cdan34's Avatar
If that was all I had, I would likewise weld or braze an extension.
cdan34 is offline   Reply With Quote
