Old 04-26-2020, 06:07 PM   #1
rivcokid
rivcokid's Avatar
Default Scraping noise from engine
Hi all - when I start up my 1931 roadster, I hear a very audible noise that I can only describe as a scraping noise coming from the engine. It is cyclical and does not increase/decrease with engine rpm. There is no effect on performance, and after a few minutes it goes away and the engine sounds fine. I may not be doing the description of the noise much justice, but that's kind of what it sounds like. Any ideas? Thanks in advance!
rivcokid is offline   Reply With Quote
Old 04-26-2020, 06:17 PM   #2
Sunnybrook Farm
Sunnybrook Farm's Avatar
Default Re: Scraping noise from engine
You might start by taking the tension off of the fan belt and slipping it off the generator pulley to see if it is coming from that area of the engine.
Sunnybrook Farm is offline   Reply With Quote
Old 04-26-2020, 10:40 PM   #3
30 Closed Cab PU
Use a broom handle as a stethoscope, see if you can narrow down where the noise is coming from. Careful around the belt and fan, if still makes it with the belt off trouble shoot with the belt off for safety purposes.
30 Closed Cab PU is offline   Reply With Quote
Old 04-27-2020, 12:35 PM   #4
rivcokid
rivcokid's Avatar
Thanks - will try this weekend
Old 04-27-2020, 02:39 PM   #5
Marshall V. Daut
Check your private messages in the upper right corner of this webpage.
Marshall
Old 05-23-2020, 04:01 PM   #6
rivcokid
rivcokid's Avatar
Hi all - Well, as it turned out, the noise had nothing to do with the fan belt, which seems to be fine. The distributor had apparently not been oiled recently, or enough. When I pulled out the oil pin and put rather a bit of oil into it, the noise all but went away. After driving it for a while, it was very quiet except under a load. I don't know if that will go away by itself after I drive it more, or if the distributor will need to be removed and rebuilt. Either way, that was the cause. Thanks much for your help!
Old 05-24-2020, 08:37 AM   #7
1931 flamingo
1931 flamingo's Avatar
Add some more oil to the fitting on the dist.
Paul in CT
Old 05-24-2020, 10:56 AM   #8
1crosscut
1crosscut's Avatar
Glad you found the trouble. Myself in your situation I'd be pulling that distributor and look it over.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-24-2020, 11:26 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
I once saw an adaption of a cup type oiler to a Model "A" distributor on this forum. For touring, the oil cup is a good idea.
Bob Bidonde
Old 05-24-2020, 12:37 PM   #10
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Your upper bushing may be worn. If you can move the cam under the rotor sideways at all, replace the bushings. Easy job.
Jacksonlll is offline   Reply With Quote
Old 05-24-2020, 02:02 PM   #11
rivcokid
rivcokid's Avatar
Thanks again. I'll get right on that bushing and see if it just needs oil or replacing.
Old 05-25-2020, 08:45 AM   #12
30 Closed Cab PU
If you do not want to rebuild your own, here is an option, allows you to reuse some of the parts on your distributor. $40 + $35 refundable core charge.
https://modelastore.com/index.php?ro...&category_id=0
Old 05-25-2020, 09:46 AM   #13
rivcokid
rivcokid's Avatar
Hi all - well, those who know better (i.e. all of you and not me) prevailed! I oiled the bushing inside the distributor and VOILA! no more noise at all - at idle or under a load.
Thanks again!!
