Old 04-23-2020, 03:27 PM   #1
DRG-ler
DRG-ler's Avatar
Default Spark plugs with interference suppression?
Hi Guys
I have some problems using electronic devices in my 30s Tudor. The electronic flasher has blown. Probably due to induced surge pulses from the vehicle electrical system. But since I want to use additional electronics in the future, I'm now looking for the problem!
One idea was the lack of interference suppression for the ignition system. Therefore, I ask myself whether there is a spark plug for the original fourbanger with intrigued interference resistance. So spark plugs with 7 / 8x18 thread. Is there anything known?
Greetings from Berlin
Andy
DRG-ler is offline   Reply With Quote
Old 04-23-2020, 04:22 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Spark plugs with interference suppression?
Andy-
The original spark plugs will generate noise that you will hear on a radio.
Noise in the electrical system (that would damage electronics) is coming from the charging system (alternator, generator). Spark plugs with noise suppression will not help with that.
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 04-23-2020, 04:33 PM   #3
DRG-ler
DRG-ler's Avatar
The generator is an electronically controlled one. I do not trust such disturbances.
What else can be the cause?
I just want to exclude all possibilities.
Greetings Andy
Old 04-23-2020, 04:39 PM   #4
Werner
Werner's Avatar
Andy,
die LiMa muß mit einem Kondensator abgeblockt werden. Z-Kerzen müssen mit "R" codiert sein.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-23-2020, 04:49 PM   #5
DRG-ler
DRG-ler's Avatar
Hallo Werner, heut mal in Deutsch, das freut mich.
Der Kondensator... hast du da ne nähere Info zu? Nen Elko, oder was anderes? Wo anklemmen? Direkt zwischen Ladeausgang und Fahrzeugmasse?
Danke schon mal im voraus.
Old 04-23-2020, 05:39 PM   #6
Sunnybrook Farm
Sunnybrook Farm's Avatar
I have noticed videos with the interference from the model A showing up. I remember when I was a kid and we had over the air analog TV sets (black and white) and I could tell when someone was coming down the road as I could hear a buzzing type of static on the TV and there would be a line of static form on the picture. When the car stopped at the stop sign I could tell the RPMs decreased then got higher when they pulled away. So it is an old problem and ways to correct it from what I remember but it may be a lost art since people don't listen to AM or Antenna TVs. Military vehicles had condensors or something on the regulators to not screw up there own radios I think.
Sunnybrook Farm is offline   Reply With Quote
Old 04-23-2020, 05:40 PM   #7
Pete
Put a .01 COAXIAL cap in SERIES with the OUTPUT terminal of the generator. Be sure the cap is rated for at least the full output of the generator.
(Note this is NOT the field terminal)
Note this type of cap goes in SERIES, not to ground. The case of this type of cap is the ground. Be sure the case of the cap is grounded.
They can be had at electronic parts stores.
To use resistor plugs, you may have to use 14mm adaptors in the plug holes.
At one time in the past, someone made plug resistors that snapped on the spark plug and the wire then plugged in the resistor unit.
Old 04-23-2020, 07:23 PM   #8
Jim/GA
Jim/GA's Avatar
This is probably the best first step. I would also recommend you check every single electrical connection on the car, especially the terminal box on the firewall, for clean, tight connections. The battery serves as a big condenser, so make sure all battery connections are clean and tight.
My friend put an electronic backup camera on her car and the noise in the power feed was very bad. She investigated all wiring and found a bad connection. When that was corrected, the signal improved quite a bit and the image was better.
Jim Cannon
Old 04-24-2020, 12:31 PM   #9
Smog Tech
Smog Tech's Avatar
I use resistance spark plug wires on my Model A. Recommended by Pertronix the maker of my electronic ignition.
Smog Tech is offline   Reply With Quote
