04-23-2020, 02:54 PM | #1 |
Insulation material
What is the consensus in the Model A kingdom about what type of body panel insulation material to use. I did a search on Fordbarn and see there is a product called Dynamats that some have used.
Is it better to use a cut and peel material or something that can be sprayed on from a can. I would prefer to use something I can get from Home Depot or Lowes. Also something that will stay in place and not absorb moisture. Tom Endy |
04-23-2020, 03:42 PM | #2 |
Re: Insulation material
Hey Tom. I installed Dynamat in all my body panels and floor, including under the seats. It really made it feel solid and quiet.
I installed jute padding on top of the Dynamat on the floors for heat. Sorry, I can't compare with other products tho, as I never used anything else. Last edited by Y-Blockhead; 04-24-2020 at 11:51 AM. |
04-23-2020, 03:51 PM | #3 |
Pictures of floor... Dynamat, Jute insulation, Carpet on top. Cozy.
04-23-2020, 05:55 PM | #4 |
Tom, the Dynamat is not an insulator. It is a sound dampener with no real R value. The big box stores will sell a bubble foil insulation that can be used. Rockwool is another that is good. It is water resistant and as soon as it dries, it is back to normal R value. The jute works well too and can be glued to the foil insulation. Use Weldwood Landau & Top Adhesive for this.
04-23-2020, 06:16 PM | #5 |
Dynamat make numerous products. Dynamat is a sound insulator as Brent said. They also make Dynaliner, Thermal Insulator. http://www.dynamat.com
04-23-2020, 08:03 PM | #6 |
If you've not attached the top yet I would place it between the batting and vinyl, I personally love the exposed chicken wire. I'm not sure how I'm going to finish above the belt line yet, but as I already said huge improvement with what I've already done, and the price is great. https://www.usenergyproducts.com/col...ore-insulation
"Avoid Model A Mythsteries. Read, study and challenge ALL advice with current logic, chemistry and technology!" author unknown |
04-23-2020, 08:15 PM | #7 |
Here are a couple of pictures
Sent from my SM-G975U using Tapatalk
04-23-2020, 08:43 PM | #8 |
Maybe something I do not understand from the pictures. Is teh mat attached/glued to the floorboards? If yes seems it would be difficult to get to the battery/etc.
04-23-2020, 08:57 PM | #9 | |
Don't be fooled by the glare from my LED light the firewall is a black ABS insulated panel. https://www.snydersantiqueauto.com/P...earchByKeyword
"Avoid Model A Mythsteries. Read, study and challenge ALL advice with current logic, chemistry and technology!" author unknown Last edited by lsr490; 04-23-2020 at 09:00 PM. Reason: clarification |
04-23-2020, 10:49 PM | #10 |
04-23-2020, 10:59 PM | #11 |
The 3m stick in panels do well and are waterproof . It can be purchased At the body shop supply houses.
Larry |
04-23-2020, 11:10 PM | #12 |
04-23-2020, 11:26 PM | #13 |
There is a material sold at Lowe's that is made for the roofing industry. It comes in a roll about 10" wide. It is a foil similar to Dynamat, with a very sticky backing about 3mm thick. It is a fraction of the cost of Dynamat and an effective sound deader. About $10 a roll. It's a roofing product, so you know it sticks for good. I used it throughout my RPU cab.
04-24-2020, 07:25 AM | #14 | |
https://www.lowes.com/pd/Peel-Seal-I...ashing/1018733 Used 3 layers in doors & behind kick panels and 2 layers elsewhere as sound deadener. Made a huge difference. Last edited by dmaxweb; 04-24-2020 at 07:31 AM. |
04-24-2020, 10:40 AM | #15 |
Adhesive types - any concerns when used in door/body cavities of holding moisture?
04-24-2020, 10:53 AM | #16 |
That was my concern, that is why I used the product I used. If you cut it 1/8" larger the the vertical surface it will stay in place on its own. As you can see my only experience is with a CCPU, cars may have different challenges. The product that M2M and others have mentioned is similar or the same. The filer between the foil is recycled milk jugs. I would not use the bubble wrap that is sandwiched between foil.
"Avoid Model A Mythsteries. Read, study and challenge ALL advice with current logic, chemistry and technology!" author unknown Last edited by lsr490; 04-24-2020 at 10:54 AM. Reason: sp |
04-24-2020, 11:11 AM | #17 |
lsr490 - Thanks for the tips/info. I tried the link you posted in post 6 - get a 404 page not found error.
My A is also a ccpu, and additionally liked seeing your install of seatbelts - a future project I need to consider. |
04-24-2020, 11:42 AM | #18 |
I'll try to update the link this evening
04-24-2020, 12:00 PM | #19 | |
Also in the pictire below, you can see the top of the Dynamat is above the bottom of the window so any water getting past the window seal will flow on the outside of the Dynamat. And lastly, it doesn't rain much in SoCAl. And when it does I don't drive the Ol' Girl. |
04-24-2020, 01:21 PM | #20 |
I used two layers of Dynamat Extreme, custom cut to top of cowl, applied with a small roller; great stuff to work with. I then had custom carpets installed and couldn't be happier!
