Old 04-09-2020, 09:01 PM   #1
CA Victoria
CA Victoria's Avatar
Default Flathead Air Pump
Saw this on the Bakersfield Ca Craigslist, interesting piece worth sharing a couple of pictures........
File Type: jpeg 75B0447D-81CC-4B2A-BF3F-CAEEEACF4F55.jpeg (66.9 KB, 304 views)
File Type: jpeg 1283E225-421A-4CBB-8F4B-B3EB836BEB6A.jpeg (64.4 KB, 304 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 04-09-2020, 09:02 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Flathead Air Pump
Belt driven...
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 04-09-2020, 11:53 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Man, that's startin' to make me dizzy trying to wrap my head around exactly what's going-on here, or even what the need for it would be. Why and where is that big 2" (or maybe even 2-1/2") inlet pipe coming from? I DO see the provision for the belt drive. So....WTF, over? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-10-2020, 01:06 AM   #4
papanomad
papanomad's Avatar
air compressor?
papanomad is offline   Reply With Quote
Old 04-10-2020, 01:15 AM   #5
48-710
I guess that they made do with a 8ba head gasket at some time. You gota do what you gota do. I think that the inlet valve is closed on the compression stroke.
48-710 is offline   Reply With Quote
Old 04-10-2020, 01:21 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by papanomad View Post
air compressor?
Well yeah it's an air compressor, but too many "why" questions about it. For instance, why did someone find it necessary to use a two-inch diameter outlet pipe? Think about the size of a single exhaust pipe on a '40 Ford. That's way overkill for the volume of compressed air that flatty will produce. It's also not necessarily gonna be easy to set that rig up and power it with another belt-drive power source, not to forget some sort of compressed air receiver tank. Just seems overcomplicated for what could be done with more traditional, and simpler equipment. But what do I know? DD
T5 W/TORQUE TUBE
Old 04-10-2020, 01:44 AM   #7
dumb person
dumb person's Avatar
Maybe the larger diameter pipe was so oil vapour would settle out.
I wonder if they used super soft springs on the intake so it'd still intake on the firing stroke?
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 04-10-2020, 03:23 AM   #8
flatheadmurre
flatheadmurre's Avatar
I have 2 Schramm air compressors of the medium size version where they fire on 4 and pump on 4 cylinders.
The big versions was 2 flatheads bolted togetter...one driving the other one that was pumping air.
Old 04-10-2020, 07:17 AM   #9
Frank Miller
Frank Miller's Avatar
If all valves were made inoperable and a poppet valve was fitted at the intake port this setup makes sense. Maybe not the most efficient but you work with what you have.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 04-10-2020, 07:31 AM   #10
Mart
Mart's Avatar
I think it was home made and just an engine hooked up so it moves air. It looks to have a big flat belt drive at the flywheel. Without seeing if all the valves have been modified, it's hard to work out exactly how it works. If it were a stock engine it work work like that, but would be more efficient depending on if other mods were made.
It's a pre 8BA motor and has had the bell trimmed off, effectively making the block scrap. Shame. It might still yield up some useful parts though if cheap enough.
Old 04-10-2020, 09:50 AM   #11
Terry,OH
Terry,OH's Avatar
Maybe it uses compressed air to turn the belt as an output.
Old 04-10-2020, 11:12 AM   #12
Ross F-1
Ross F-1's Avatar
There's no cam drive, so something like that "almost" makes sense.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-10-2020, 11:21 AM   #13
flatheadmurre
The pulley is probably just a 9" flywheel that has been machined.
Old 04-10-2020, 11:58 AM   #14
CA Victoria
Belt Pulley is a circular piece around a flywheel?
Skid mounted, set up for a large electric motor?
One way air valves on each cylinder?
No apparent cooling mechanism other than air cooled?
High volume low pressure pump.......Bakersfield area is known for oil production, may be related?
Tim
Downtown, Ca
Old 04-10-2020, 01:35 PM   #15
frnkeore
frnkeore's Avatar
Regarding the pipe, since the exhaust is blocked off, it would be running 2 cycle and twice the original capacity.
Maybe the exhaust lobe has been ground off and the close ramp modified on the intake?
It could be a piece of farm equipment, run by the flat belt drive of a tractor or a overhead line drive, in a shop.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 04-10-2020, 01:48 PM   #16
skidmarks
skidmarks's Avatar
If it were close by and cheap i would buy it. I like it just for the make due with what you got approach. Someone did spend some time making it. Seen alot worse done on some current "hot rods"
The check valves in the sparkplug ports look like common air compressor unloader valves with the small port plugged
skidmarks is offline   Reply With Quote
Old 04-10-2020, 04:27 PM   #17
flatford8
flatford8's Avatar
With hose clamps on all the connections it must not have built up a lot of pressure. I agree with buying it if it was close by. I bought a stationary engine that powered a water pump at the paper mill in Westbrook, ME....... Mark
File Type: jpg E9383157-3838-4FD6-8163-FE85C0416319.jpg (68.1 KB, 33 views)
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
