Old 04-08-2020, 06:41 PM   #1
G.M.
Default Starting with a bad coil
Not much to do so I went looking on old Early Ford V/8 Forum
There was a long thread in 2015 about a V/12 Lincoln being
hard to start. From all the info I would say it had a bad coil.
What fooled them was after it sat 10 or 15 minutes it would
start when they gave it a shot of starting fluid. It did not have
the correct carb on it and most people blamed that. I think the
real problem is what I see on here, a lot of BAD coils that get
weaker the hotter they get. When the spark gets A LITTLE weak
and won't start they will usually fire and run if starting fluid is
used. The starting is more combustible and fires with a weaker
spark. The lincoln V/12's have a big one piece coil that has two
36 Ford coils inside. G.M.
www.fordcollector.com
