Old 04-08-2020, 04:54 PM   #1
AnthonyG
AnthonyG's Avatar
Default Mounting Flywheel question
What’s the reason for the shim? When I first received my rebuilt 8BA 6 yrs ago I had issues w the one the builder used. I bought a new one & reassembled based on pics I took. Thinking it was never assembled correctly as the radial shim was installed under the bolts instead of between the crank & flywheel. As a machinist I don’t see the reason for the shim behind or in front of the flywheel? Is it really performing any function?
Nomad
AnthonyG is offline   Reply With Quote
Old 04-08-2020, 04:57 PM   #2
JWL
Default Re: Mounting Flywheel question
The plate is intended to retain the dowel pins when assembled to the outside.
JWL is offline   Reply With Quote
Old 04-08-2020, 06:32 PM   #3
AnthonyG
AnthonyG's Avatar
Thx, Not a shim at all! A sure locking method! Got it.
Nomad
