Old 04-06-2020, 06:10 PM   #1
jim1932
jim1932's Avatar
Question White residue on Model B fuel pump
Any idea what this white stuff is? Won’t clean off.
File Type: jpeg 032EDB67-DBC9-4BE4-8080-E41D2D048A8F.jpeg (157.1 KB, 58 views)
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 04-06-2020, 06:43 PM   #2
DavidG
DavidG's Avatar
Default Re: White residue on Model B fuel pump
It will clean off. Disassemble it down to the castings and dip them in metal prep briefly. Only briefly as the metal prep will eventually attack the zinc as well as the white zinc oxide that you are trying to remove.
Old 04-06-2020, 07:54 PM   #3
paul2748
paul2748's Avatar
Looks like plain old oxidation ??
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-06-2020, 07:56 PM   #4
G.M.
This usually come from water or real damp conditions. G.M.
"High humidity"
www.fordcollector.com
Old 04-07-2020, 06:01 AM   #5
jim1932
jim1932's Avatar
I had put them in a water proof storage container they still smelled of gas at the time.
Old 04-07-2020, 06:32 AM   #6
jim1932
jim1932's Avatar
so like POR 15 prep? then rinse in? Water? water with Bacon soda?
Old 04-07-2020, 07:54 AM   #7
DavidG
DavidG's Avatar
I'm not familiar with POR 15, sorry. I use metal prep (phosphoric acid) and yes, rinse with water and dry thoroughly with a hair dryer or air hose.
Old 04-07-2020, 02:40 PM   #8
mcgarrett
Glass bead blasting works very well too.
mcgarrett is offline   Reply With Quote
Old 04-07-2020, 02:40 PM   #9
mcgarrett
Glass bead blasting works well too.
Old 04-16-2020, 02:08 PM   #10
jim1932
jim1932's Avatar
Thanks, Related question. The parts book only show one petcock, 9185 to be used across fuel pumps. I thought I saw somewhere that there was an early and late on a 32 B pump. Asking because I have one pump where the petcock bottoms out on the spring before sealing. It doesn't do it on a different pump. Is it a bad seat? (FYI, it is not this pump that has the issue)
Old 04-17-2020, 07:41 AM   #11
Terry,OH
Terry,OH's Avatar
Try installing the pet cock without the spring does it seat properly?
Old 04-17-2020, 08:07 AM   #12
DavidG
DavidG's Avatar
Jim,
There were two different pet cocks used on '32 fuel pumps matching differences in the pump bodies. The early version is hollow and has holes in the tapered end of the pet cock to permit the pump to be drained without completely removing the pet cock from the fuel pump body. That pet cock version is used with fuel pumps that have no drain hole in the pump body.
The second version of the pet cock is solid and a drain hole was added to the pump body at the same time. The two pet cock versions are the same size overall and can be used interchangeably except if the second version is used on a early pump without a drain hole in the pump body, the pet cock must be removed completely in order to drain the pump.
So, in answer to your question, I'd pull the drain cock from the pump and inspect the seat in the pump body for excess wear and if it looks okay, do as Terry recommends. If the drain cock seats without the spring, perhaps the spring is too long and not the right one for that application.
Old 04-17-2020, 09:03 AM   #13
jim1932
jim1932's Avatar
Interesting, did some experimenting, I happen to have 4 pumps plus an extra main body. They all look identical and have the later side hole. The same same petcock, fits 3 without bottoming out on the spring, but bottoms out in the other two. These are the two I have had the longest and been frustrated with leaks. I guess I found my issue. Next experiment will be to take the spring off and see if they leak. I know I need a spring, but if they don't leak without the spring, I can maybe get a slightly shorter spring.
